ge washer
#1
Guest_scoutfive_*
Posted 18 April 2005 - 07:09 AM
#2
Posted 18 April 2005 - 09:02 AM
#3
Posted 18 April 2005 - 10:55 AM
How do you get it to agitate if it won't fill? Have you bypassed the pressure switch?It won't fill or spin. I've taken the front off and I am still lost. It agitates though...
#4
Posted 18 April 2005 - 12:41 PM
#5
Posted 18 April 2005 - 12:43 PM
#6
Guest_david_*
Posted 18 April 2005 - 12:49 PM
#7
Guest_David_*
Posted 18 April 2005 - 12:51 PM
David
#8
Posted 18 April 2005 - 01:29 PM
#9
Posted 18 April 2005 - 02:37 PM
#10
Posted 18 April 2005 - 02:59 PM
#11
Posted 18 April 2005 - 05:37 PM
#12
Posted 18 April 2005 - 05:51 PM
Looks like Mad Mac's first reaction was correct.
#13
Posted 18 April 2005 - 06:08 PM
#14
Posted 22 April 2005 - 12:40 AM
Luckily I only flooded a garage with a cement floor when I forgot, could have been worse.
after you take the tube off to clean it,
cut 1/8th inch off the end to assure a tight connection.
#15
Posted 02 December 2008 - 05:23 PM
Is there any way to remove this box and clean out the shmutz?(Is this called the "air dome"?)Clean the schmutz out of here with a small flat screwdriver. Or get mildly violent with the water level switch. Move it roughly all the way back and forth a few times.
I've replaced the pressure switch, but I still seem to have the problem. It fills up, and doesn't stop to start the agitate cycle. When I took off this hose, it made a squeeking sound, but then I replaced it and it advanced.
Anyhow, it looks like there is some gunk in there which sounds like it might be the problem.
Enjoy the brewskis! Hope someone here can help me. :D
