Admiral LNC6750A71 spin problem troubleshooting
7 replies to this topic
#1 Kelfin
Kelfin
  • 16 posts
  • Flavorite Brew:Homemade fruit soda or chocolate milk. Amaretto sour on a bad day.
Posted 27 August 2009 - 12:24 PM
I've managed to remove the agitator and inner drum of my Admiral top-loading washing machine, model LNC6750A71.
Please check out the photo.  I have the following questions:
1) Do I need to remove the outer drum to get to the transmission and clutch?   If so, what tool do I need?  My socket wrench doesn't fit under the big metal ring (the mount for the inner drum?), and my wrench doesn't fit between the fins to the left and right of the nuts.
2) Am I on the right track to hunt down what's causing my washing machine to spin poorly / slowly?
3) The transmission/clutch for this model is all one piece.  It's all one $300 piece.   Have I entered the land of the "may as well get a new washer"?
Thanks!
- Kendra
#2 RegUS_PatOff
  • Academy Instructor
  • 33,588 posts
Posted 27 August 2009 - 05:54 PM
Admiral LNC6750A71
may be similar     c 1996
Jenn-Air JW2000 Service Manual  Posted Image
#3 nickfixit
nickfixit
  • 2,190 posts
  • Flavorite Brew:Glen Livit
Posted 28 August 2009 - 01:44 AM
You will also need the tub seal and bearing kit, figure $80-$100 more in cost. Also, check the tub support, aka milkstool, for cracks and breaks.
I would junk it.
#4 completeapplianceservice
    Sōhei
  • Master Appliantologist
  • 244 posts
Posted 28 August 2009 - 09:50 AM
i would try replacing the belt first if you haven't already, if that doesn't take care of it, it could be the thrust bearing assm. basically its the drive pulley assm as well as some washers and a bearing. its not to bad to replace it.
#5 Trying to help
Trying to help
  • 2,464 posts
Posted 28 August 2009 - 10:34 AM
Take a gander at the link below.  It addresses no spins on a MAV unit which is the same drive system.  One quick check will tell you if it is the trans or brake not releasing.
http://fixitnow.com/...ashing-machine/
Slow spins are usually not the trans, belts as mentioned prior, motor pivot plate not allowing the motor to snap back (Dry or gummed up), etc. are the usual culprits.
If we saved YOU Beer $$ today, please make a donation to our beer fund by clicking the link below to help keep this site going. I charge $135.95 PLUS PARTS to do this repair!$! http://fixitnow.com/beerfund.htm
#6 Kelfin
Kelfin
  • 16 posts
Posted 28 August 2009 - 12:19 PM
I checked the belt - no glazing, not shiny, no cracks.   Can it have other damage that wouldn't be visible, or can I assume it's OK?
Does silicone vs. bearing grease matter for lubing the motor pivot?   That doesn't look damaged, but it's definitely stiff and hasn't ever been lubed before.
Thanks!
#7 completeapplianceservice
    Sōhei
  • 244 posts
Posted 28 August 2009 - 01:13 PM
the belt is the easiest thing to replace and inexpensive. if the washer has any age on it, it's just a good maintenance item to replace.
silicone is normally more of an adhesive or sealant, i would stay away from that. Vaseline is something you could use that you might have around the house.
#8 kdog
    RoughShod
  • 7,466 posts
Posted 29 August 2009 - 05:29 PM
The thrust bearing mentioned in your second post is located under the machine, and is part of the large centre plastic pulley, if you wish to remove the trans, the milstool and springs need to be removed and the tub flipped over to remove, but first you need to remove the nut from the top, at the bottom of the innertub. Please refer to the tests in the link that TTH provided in a previous post prior to making any "parts replacing" decisions.
