How to get to an Admiral washer belt
3 replies to this topic
#1 Kelfin
Kelfin
  • 16 posts
  • Flavorite Brew:Homemade fruit soda or chocolate milk. Amaretto sour on a bad day.
Posted 29 August 2009 - 11:01 AM
I think the replacement of Admiral washer LNC6750A71 belt is looming.   Because the belt is located under the chassis of the washer, how do I access it?
Do I
a) Flip it on its back like a turtle and risk damaging the pipe intakes?
B) Flip it on its side like a cow and risk damaging any hanging things I'm not aware of, like the motor?
c) Lift all four corners with blocks and slide under it like a car?  (And risk dropping a washing machine on my head like I was the Wicked Witch of the East?)
d) None of the above
#2 NCSU_laundry_tech
NCSU_laundry_tech
    Senpai
  • Appliantologist
  • PipPipPipPip
  • 940 posts
Posted 29 August 2009 - 12:34 PM
lean it back against the wall perhaps. make sure the problem is not just the thrust bearing before you buy a belt
To alcohol! The cause of... and solution to... all of life's problems.
#3 Kelfin
Kelfin
  • 16 posts
Posted 29 August 2009 - 01:05 PM
I've scoured the diagram at repairclinic.com (http://www.repaircli...pliance-Diagram) and can't figure out where the thrust bearing is hiding.
If it's in the transmission, then I'm back to my original problem, namely I can't get that darn outer tub off to get to the tranny.  Unlike the Maytag diagram, the entire transmission is encased and I can't get to it from below without a blowtorch...at least that's what it looks like to me...
I'm sensing that I'm missing some key concept here...
#4 RegUS_PatOff
  • Academy Instructor
  • 33,588 posts
Posted 29 August 2009 - 01:38 PM
LNC6750A71
may be similar Cabinet
PAV5000AWQ Service Manual
after the Top is removed:
http://www.partselect.com/Schematics/Maytag/52518.gif
