Whirlpool Washer WTW5530S00
7 replies to this topic
#1 jatjtx
jatjtx
  • 4 posts
Posted 03 September 2009 - 09:38 AM
Loaded with water but will not work further regardless how much I fiddle with the controls or tub-lid
#2 NCSU_laundry_tech
NCSU_laundry_tech
    Senpai
  • Appliantologist
  • PipPipPipPip
  • 940 posts
Posted 03 September 2009 - 10:25 AM
lid switch perhaps
To alcohol! The cause of... and solution to... all of life's problems.
#3 RegUS_PatOff
  • Academy Instructor
  • 33,588 posts
Posted 03 September 2009 - 11:45 AM
WTW5530S00
perhaps
WTW5530SQ0 Wiring Diagram
Try it in the Spin Cycle ...
(the Lid Switch stops all Motor activity on that model)
Does the Motor hum at all ?
Could also be a bad Timer, Motor, or Water Level Switch ..
You may have to do some voltage tests ..
#4 jatjtx
jatjtx
  • 4 posts
Posted 03 September 2009 - 11:58 AM
No humming from the motor - water level stopped at the correct level --- I think the lid-switch is a good place to start........that is my gut feeling w/o running any voltage tests.
#5 RegUS_PatOff
  • 33,588 posts
Posted 03 September 2009 - 12:16 PM
and other Cycles ... Delicate, etc ...
#6 jatjtx
jatjtx
  • 4 posts
Posted 04 September 2009 - 04:32 AM
All cycles.
#7 RegUS_PatOff
  • 33,588 posts
Posted 04 September 2009 - 09:35 AM
You could check the Lid Switch (White to Grey) with an Ohm Meter,
OR measure the voltage across it (White to Grey) while running.. (should be 0v AC)
OR by-pass it (White to Grey) for testing ..
#8 jatjtx
jatjtx
  • 4 posts
Posted 04 September 2009 - 09:54 AM
Thank you - I plan to work it tomorrow and devote the proper attention ot it.
