Learn how to be your own tech line…
je
Sears service man says there's nothing wrong!! HE2t front load
12 posts in this topic
My Kenmore front load HE2t has always shook like crazy on even medium speed spin.
I read the faq, and expected to find shock absorber, bearing, or even spider problems. However, I have a 3 year dervice plan... so I called them in.
I wasn't the one home for the appointment, but the tech looked at the shock absorbers, pronounced them A-OK, and stated that there's nothing wrong. The pedestals make the shaking worse - We just don't fill it enough, causing unbalanced loads.
This doesn't sound right at all. I've seen front loads half full that don't visibly shake at all. I wish I was home for the appointment, I'd have mentioned the bearing or spiders. Why would he do such a quick check and pronounce problem solved?
What recourse is there now? Should I call back with a note about the bearing or spiders?
a half load doesnt always balance properly. what type of flooring is the washer installed on? is it on a wood subfloor, or cement slab?
it's on the cement slab that the house is on. It's also levelled - with a level!
how are the feet? are they in good shape and clean? the first thing i look at on this type of call is making sure the rubber feet and floor are clean and oil free so they can grip. The washer may be level but the legs may not be adjusted so they are each supporting 1/4 of the weight, sometimes a slight 1/2 turn of one leg is all that is needed to regain stability.
YouTube video ?
On part loads , make sure everything in washer is sort of the same - towels, tee shirts , jeans , etc. Mixing these things can cause problems. Next , take two $100 bills and put one under each front foot - now when spinning see which bill pulls out and tighten that leg. Then tighten the lock nuts..   Water pumping out o.k.?  Also , I think there is a service flash that wants you to put an extra brace , etc. on the washer. Will look on Fri. and see if I can find.Hope someone here can give you the info.
that he2 and its sister the duet sport shake more than any other front loader. is it walking along the floor? if so you can get pads to go under the feet at lowes. it would shake less if you removed the pedestal.
After checking all our hints , and it still walks - put some shelf liner(the stuff that keeps things from moving around) under the feet of your unit. A cement floor is not the most level and even floor , so a little movement could put the washer in a slight wiggling position which would make it move a little more and away we go.
At last I found the service pointer for the he2.  www.servicematters.com     ref#8178772              You need kit# W10252502                    I have never seen let alone instal one of these kits , so do not know how much help they are. If you do this , please let us know .. Good luck:)
even though a tech has looked at it, i would take the time to read the manual and inspect to make sure the shipping braces were removed when the machine was first installed
i've seen machines used for more years than yours and looked at multiple times before i went out and removed the braces
you said it is on a pedital,pull the drawer out you will find a hex screw on each side holding the rails on,remove screws push rails back remove drawer, but in a load on rinse and spin. the feet heads have 1/4 in. hex on top,get 1/4 in socket and ratchet,as it starts to  spin you will find one leg pogoing up and down, run that leg down, test each leg till you use the same torqe, this will stop the walking, they all shake some, we are all assuming the shipping bolts are removed.....you remove the drawer to get to the rear legs,forgot to mention that
The braces are definitely off :)
Magically, the thing doesn't shake now. The tech put it back right where it was, backed in the corner at an angle, but it doesn't shake (it was very dramatic before). I have to check if he levelled it (not like I haven't levelled it too).
I'm afraid to put it back even with the dryer and walls since the concrete floor isn't exactly level (move the thing around and you'll find out).
