Miele Dryer Model T1576 Service Manual Request
148bth
Hi All,
After much searching could not find any info for Miele T1576 dryer.  Problem=door will not stay closed/latched.  Possible faulty lock mechanism [Miele p/n 3721391] got this # from Miele in Princeton, NJ.  Miele will send me the part but not the service manual unless I'm an authorized Miele Svc Co [which I'm not] Soooo...does anyone have one of these or could the point me in the correct direction to find one.  Also as a newly paid noobie member is there a link to browsing manuals or am I just a dork and can't find it?  Finally does anyone know if the door on this unit is reversable, I'm tired of it hitting me in the a** every time I empty the washer.
  • Replies 8
  • 148bth
  • kdog
Does it come w/part #'s for the various components?  If it the  T1300 - T1400 use p/n 3721391 for the lock/latch mechanism then this SM might just do the trick.  Could you fwd it to me?
Reg US! Thanks for all help!  Looks similar as far as I can tell but I am not actually in front of the offending unit.  Do you know if there are part lists out here in cyberspace?  Do you know if there is a known way to test the door lock w/a multimeter or any other device?  Also do you know what:
Door Switch Test - Buzzer operates
when the door is closed.
found on pg 71 in Table 060-6: Service Mode
means/pertains to?
In the mean time anyone else have any ideas why the door wont stay closed/latched?  Anyone else have a link to the T1576 Service Manual?
Where? My email? I can't seem to find them. I hope I did not just trash them when I emptied my junk mail box! :shock:
  • 3 weeks later...
I did & I am still trying to decipher it, however; I believe "kdog" has shown me the light [section] I needed.
Will keep all informed on my progress or lack of.
Thanks!
