LG WM2377CW Front load washer Service Manual
Guest
 Hi.
 Looking for a Service Manual for an LG washer that I bought in Canada at SEARS in Dec of 2006........ Model WM2377CW.
Also listed on the user manual that came with it was WM2477  but MINE is a 2377
So I assume the 2477 might be close.
I can't seem to find much about this washer model in any forum........ I wonder if that model is Canadian and or it might be listed as another model number in the US or elsewhere.
I have the damm musty smell although getting better with the tub clean cycle I might have to take it apart and give a real good cleaning
Thanks for your help........
  • Replies 8
Shouldn't be a need to take it apart.
Our LG developed a musty smell after about a year...
I checked under the Lip of the Door opening Seal and found some gookus.
Dirty soap suds splash up there and collect, and normally, the water level doesn't get that high to keep it rinsed.
I cleaned that, and now run a Tub Clean Cycle once a month ...
Here's a similar xx77  LG Service Manual
I sorta agree about taking apart .......... not going to unless I have to
I seen a picture on the net of someone that took there's apart and the inner tub was coated ALL OVER with  the "gookus" you are talking about.
After numerous TubClean cycles I got rid of the smell and the gookus that was underneath the rubber seal on the edge of the tub........ I am just not sure what the rest of the tub looks like based on the picture I saw and the fact that the smell started coming back after about 2 weeks.  Makes me think after almost 3 years use that there could be a lot built up and not getting cleaned out.
I did a tub clean cycle last night and watched how clean the water was.... there was still some large pieces of the gookus showing up. I figure as long as the tub clean cycle is fairly clean then the washer should be clean and the last one of those 2 weeks ago was clean
I have done a lot of reading on the FL smelly washer problem and found that it could be a number of things. We have changed what we use and how we use it and it seems to helping with the smell
Anyway I thought if I could get my hands on a service manual now it would save me sometime when something does happen to the washer during a holiday or Fri night about 5:05........ did have to take the pump apart once it had a tooth pick stuck in it
So if anyone has one it would be greatly appreciated
Thanks in advance
Sorry was to busy explaining why I might have to take it apart I didn't see that you posted a manual........ eyes are a great thing if used LOL
THANK YOU
[user=57568]DFR619[/user] wrote:
... didn't see that you posted a manual........ eyes are a great thing if used LOL ...
sometimes :ooo: My eyesight isn't as good as it once was, either
(see RegUS_PatOff
Do you have a link to the picture of the Inner Tub gookus ?
I have looked at SO many sites trying to fix the smell problem that I am not sure what one..... Give me a couple of days and I will check my history ect. I am busy 2night
That manual looks close to my washer .......a few different options
Thanks again
http://www.thriftyfun.com/tf452244.tip.html
I googled and found it first thing
There are many many stories on this and just as many answers
After reading a lot of this I think it has to do with overuse of soap and fabric softener
The temperature of the water
The hardness of the water
The more you read the more different answers you get
Whats your experience????
PS If this has carried on to far in the service manual thread please move to appropriate place
New here and not trying to get canned first thing
LOL
Thanks
or the wrong soap ..
should be HE only..
liquid soap is worse ... (made from wax)
I don't think that picture is mold gookus (it would be black), maybe other gookus from :
"My washer is 5 years old and has been through many cycles, since I've had a few room mates over the years."
feedback_image.lasso?id=83687887
That's the color of the stuff I am getting ....... between the gasket and the drum if you put your finger in there it was all covered in a brownish grey slime.
I figure if you took my tub apart thats what it looked like
You don't see it if you do a cycle without clothes in it but if you use the tub clean there are pieces in the water while the tub is cleaning
Although mine has gotten A LOT better now
I think hot water helps to get rid of it too
Probably not going to take it apart unless it keeps starting to smell every 2 weeks
And yes switched to powder and even some vinegar for fabric softener
The POSITIVE PART of this is the Soap and  FS bill are going to go way down
Hope we can figured out on the smell part
