Maytag model MSD2356AEW Refridgerator
  • This topic is locked This topic is locked
5 replies to this topic
#1 ptkid2
ptkid2
  • 2 posts
Posted 16 August 2005 - 01:54 AM
I can't figure out the right way to remove the cover over the controls in the top of the refridgerator without breaking them.  I need to get to that pesky adaptive defrost control board.  Any help is appreciated.
#2 Pegi
Pegi
  • Appliantologist
  • 13,120 posts
Posted 16 August 2005 - 06:15 AM
Perhaps this will help....
#3 ptkid2
ptkid2
  • 2 posts
Posted 18 August 2005 - 02:11 PM
Well, I just finished installing the defrost board, and this was a big help. For those that follow, on my model part 21 slides forward and slips right off. You may have to work the back tabs out of their slots. Then you remove two screws, one at each end of part 23, and remove that. Then you remove three screws holding part 1, two located in the slots at the front screwed into the top of the cabinet, and one centered on the back that screws into the back wall. The board is part 13 and rests in the low indentation in the back right corner of part 1. A one mug max project. I also manually defrosted the evaporator so everything started back clean from the start. Thanks again, this was just what I needed.
#4 Pegi
Pegi
  • Appliantologist
  • 13,120 posts
Posted 18 August 2005 - 04:13 PM
You are quite welcome....;)
#5 2FrozT
2FrozT
  • 3 posts
Posted 18 March 2009 - 02:52 AM
RE: Maytag MSD2356AEW
Hello Samurai-San !
I had a problem with frost build up on the evaporating coil before. The Maytag technician  fixed the problem by replacing the adaptive defrost control board with a new one. And now, 3 years later,  I have the same problem.
Can someone show me how to check if the real cause is a defective adaptive defrost board, and not the defrost thermostat or the defrost heater?
How can I check these 3 components to determine which one is the cause of the problem? And how can I ply open the front cover case to get to the board without breaking it?
Arigato, and I appreciate your help :D
#6 RegUS_PatOff
  • Academy Instructor
  • 33,588 posts
Posted 18 March 2009 - 04:07 AM
please start a New Topic.
This is an old unsecured thread that should be closed...
