Wanted, Frigidaire 3.5 cuft FL service manual
phreich
I've been browsing the web for a service manual for the 3.5 cuft FL frigidaire machines but have found only the manual for the 3.0 cuft machines.
Does anyone have this service manual from Electrolux in pdf format that they can share?  It should be titled something like "SERVICE MANUAL 3.5 Cu. Ft. HORIZONTAL AXIS WASHER GOOD & BETTER MODELS".
Thanks!
  • Replies 10
  • phreich
  • applianceman18007260692
model number ?
(different controls / motor controller)
(electronic / not)
[user=56974]phreich[/user] wrote:
... the 3.5 cuft FL  ..... have found ... the manual for the 3.0 cuft ...
Hi, thanks for the response with the manual -- unfortunately it is the "good and better" service manual for frigidaire dryers.  Do you have the one for the 3.5 cuft horizontal axis washers (probably would be dated 1/2005 or later).
Whoops, I just now saw you posted a link for a washer -- but it is the 3.0 cuft series which I already have.  Do you have the service manual for the 3.5 cuft series "good and better" horiz. axis washers?
Thanks for the help!
phreich
I apologize if the lack of model numbers caused delay.  I assumed (maybe incorrectly) that the elecrolux service manual for the 3.5 cuft horizontal axis washers would be combined in a single "good and better" manual as was done for the 3.0 cuft series and the matching dryers.  To be specifc, I am interested in the service manuals for last two models you posted:
Frigidaire Gallery 3.5 Cu. Ft. Front Load Washer Model: GLTF2940FS
Frigidaire Affinity 3.5 Cu. Ft. Front Load Washer Model: FAFW3577KW
Possibly the Affinity will be in a separate manual.  As has been true in the past, the manual will probably also cover the ones made by Frigidaire for Kenmore and other brands which are just cosmetically different.
I hope someone has them....
Thanks for the help,
phreich
Do you have the service manual for the 3.5 cuft gallery too?  I now understand they have different manuals due to the change in the suspension system.
Thanks!
