No Cold Water
6 replies to this topic
#1 mustvid
mustvid
  • 5 posts
Posted 16 August 2005 - 11:11 AM
Started a load of laundry today and found that there was hardly any  flow of cold water. I switched to hot and got a flow although not as much as usual. Is this a water inlet valve problem or a temperature switch problem? How do I know which it is?
#2 Pegi
Pegi
  • 13,120 posts
Posted 16 August 2005 - 12:20 PM
Whirlpool Toploader Washer LLR6144BQ0...........Normally if the temperature switch is bad you will not get any water at all, so I would suspect your fill valve is going out and you need to replace this part.
#3 Pegi
Pegi
  • 13,120 posts
Posted 16 August 2005 - 12:24 PM
Part number 285805 and is reference # 18 in this breakdown....
#4 Pegi
Pegi
  • 13,120 posts
Posted 16 August 2005 - 12:28 PM
Here is the fill valve you will need.....
#5 Pegi
Pegi
  • 13,120 posts
Posted 16 August 2005 - 12:31 PM
And here is how to access this valve, do not try to take the back off of this washer.....;)
#6 mustvid
mustvid
  • 5 posts
Posted 16 August 2005 - 01:24 PM
Thanks a million Pegi! I started to take the back off and realized after four screws that it was going to be a lot of work. I will tackle this job tomorrow!
#7 Pegi
Pegi
  • 13,120 posts
Posted 16 August 2005 - 01:28 PM
You are most welcome.....:cool:
