Demon
Evap Fan not working... need help
16 posts in this topic
OK, after looking through the forums for a little while now I thought it would be best to post this one as I had not seen anything close.
Background: Kenmore 596.5864290 Side by side with water/ice in door... REAPLACED Evap-fan motor part # 10513803
Story: OK, came home yester day and grabbed for a cold soda and to my surprise it wasn't... cold that is... anyway, popped open the freezer door and my Ice ain't Ice... more of a pool of ice in the bottom where the evap coils are. OK, so now I got big ol mess, lucky mom stopped by because wife and I were up to our necks with a mess from all the melted crap. Get everything out and cleaned up. Pull the back cover off and click it on and no fan.... AHHH HAAA!!! :shock: Next day run to parts store, go home, return to parts store with numbers that I left on desk. (useless info I know but hey) Get my new motor and head home.. should have nice frosty soda in no time!!! WRONG! :yikes: New fan popped in, twist the knob, compressor fires up and nada... fan ain't turnin... Double check wires, ground, all bolts.. NADA!!! :yikes:
I figure it must be a relay or maybe a switch problem but have no clue where to look or anything and can't find a diagram anywhere to show where to look..
Thanks in advance for any help.
Sounds like you're stuck in defrost, but re-check the model number - I can't get anything up on the one you gave (should have 8 digits after the 596.).
Looks like Maytag frig with the Kenmore name on it, but could not bring up that model number to see what is in there, can you recheck this please?
Hummmmm, would the compressor not be dead in defrost?  He said the compressor was running......
I am sorry, my fast fingers missed a diget there... 596.58642890, and yes I do belive that it is a maytag in disguise... The compressor is kicking on and the coils are icing up when it is turned on but fan won't turn to circulate the nice coldness ;)
Before you replaced the evap fan, did you check to see whether or not the fan motor was getting voltage?
Post a legible and properly oriented copy of the wiring diagram for your fridge (it's cleverly hidden in the fridge-- look around, you'll find it). On some of these, the evap fan circuit is completed through the defrost thermostat.
2 problems with that ;( one I have no way to scan the diagram, 2 it's a bit tore up from being under the fridge... but it does connect to the defrost timer and terminator both then to the temp control. I hope this helps with the figuring out of what/where I should look
Also, had a couple pretty bad storms here but no severe surges, but we did have several temporary outages.
Ohm out the defrost thermostat. Make sure it's at freezer temp first. If it's open, replace it-- that was probably the original problem.
I am slightly confused, at freezer temp?
Don't let it warm up when you test it or it will always read open and the test won't mean anything.
ahh ok so test it with everything off as it is now, and has been for the last day and a half.
Now, let's compare your reply with my unambiguous instructions:
Um, no, that would be room temperature.  Perhaps you could take it to your mother's house and put in in her freezer for an hour or two then test it?
We had the same problem with our refrigerator. After the second time, Sears replaced the sub kit, defrost. I believe by our receipt that the part number is 46464R0161088.  Our fridge would work then it wouldn't. Since they've replaced the part we haven't had any problems.
I forgot to tell you that Sears charged us $40.28 for the parts, I won't even mention the labor costs!! Well, anyway the sub kit for the defrost is what you need. Hope this helped.
