Broiler doesn't work
9 replies to this topic
#1 kickin00
kickin00
  • 3 posts
Posted 19 April 2005 - 07:59 AM
Kenmore model #362.7351190
The broiler won't light. Cooktop and oven operate fine. I have removed the igniter, it reads 80 ohms resistance. The new part from Sears reads 65 ohms resistance. I do not read any voltage going to broiler igniter when broiler is turned on. I hear a relay click, but no igniter and no gas. The relay click is in the top portion of the stove. It's not a click from the gas valve.
One appliance repair center thought maybe that there might be a relation to having used the self cleaning function on the oven roughly three weeks ago. We can't recall if we have used the broiler since then.
Any advice you can give me would be appreciated.
Thanks.
  • 24,207 posts
Posted 19 April 2005 - 05:17 PM
Post your model number!
Test the continuity of the safety valve where the wires connect to it. Remove at least one wire from the valve before measuring continuity. If it reads open, it's bad.
#3 kickin00
kickin00
  • 3 posts
Posted 19 April 2005 - 06:02 PM
I did post my model number, but it didn't show up. My stove model number is Kenmore 362.7351190. I will let you know when I check the safety valve. Thanks.
#4 kickin00
kickin00
  • 3 posts
Posted 21 April 2005 - 07:35 AM
I figured out the problem, it was a bad connection on the circuit panel.  Thanks for your help!
  • 24,207 posts
Posted 21 April 2005 - 08:57 AM
Nice shootin', Hoss!  :armed:
#6 Guest_vzerfc6f@verizon.net_*
  • Lurking at the Threshold
Posted 21 November 2005 - 07:46 AM
The oven controls started making a churning sound.  It turns off and flashes f - 1
#7 Pegi
Pegi
  • 13,120 posts
Posted 21 November 2005 - 08:18 AM
Verison.net you want to post a brand and model and serial number???
#8 Pegi
Pegi
  • 13,120 posts
Posted 21 November 2005 - 08:22 AM
F-1 usually means:
F1 Electronic range control failure.
1.  Replace electronic range control (ERC).
But cannot be sure since we do not know what  brand this and what style without the model number.
#9 busterj1
busterj1
  • 3 posts
Posted 21 November 2005 - 09:16 AM
This stove is a Kenmore model #362-7351190, Serial #17204902P
#10 Pegi
Pegi
  • 13,120 posts
Posted 21 November 2005 - 09:23 AM
Looks like the same range is in two differents threads...:?
