  • Announcements
    • Son of Samurai
      Contact the Samurai   01/01/2016
      <a data-cke-saved-href="https://mastersamuraitech.wufoo.com/forms/msvo81y1r0homk/" href="https://mastersamuraitech.wufoo.com/forms/msvo81y1r0homk/" rel="external">Fill out my Wufoo form!</a>
ciucca
Jenn-Air WW27430P Food Tempature Probe
5 posts in this topic
I am having an issue with the meat  temperature probe.  When I insert it into the oven, it intermittently starts blicking "probe" and allows the food temperature to be set.  Most of the time nothing happens when the probe is inserted.  The times when the probe appears to work it will function for a while and then just disconnect, and the oven will beep, until I press cancel.
I've checked the probe with an Ohm meter and it appears to be in range.  I also tried a new one and the problem still happens.  Anybody have an idea what the problem could be?
Thanks.
Could be a bad Probe Jack ...
check the Probe resistance (and looseness) at the Oven Controller with the Probe inserted.
WW27430P Service Manual
Thanks.  I will try that.
I finally had the time to check everything, and I have a bad probe jack.  Does anyone know the part number for this?
Thanks.
[user=1537]ciucca[/user] wrote:
...I have a bad probe jack.  Does anyone know the part number for this?...
The manufacturer has replaced part number 71001863 with this item, part number 74009649
