Hooking up power cord for dryer
6 replies to this topic
#1 Lurker_Mangoman_*
Lurker_Mangoman_*
  • Lurking at the Threshold
Posted 20 August 2005 - 07:38 PM
Im lost, hooking up the power cord for this Maytag Dryer Model DE412, my cord has 4 color connectors red/white/green/black, the inside of the dryer only has black/white/green and a separate grounding screw, what is the proper way to hook this up?
#2 Mangoman
Mangoman
  • 2 posts
Posted 20 August 2005 - 07:45 PM
Im lost, trying to hook up power cord, my cord has red/white/green/black connectors, the dryer is a Maytag model DE412 and only has black/white/green connectors with a separate ground screw, can you tell me the proper match up for hooking this up??
    Shōgun
  • Master Samurai Tech
  • 30,170 posts
Posted 21 August 2005 - 03:20 AM
On your new cord, red and black are "hot" and white is neutral.  On the old cord, the white and black were "hot" and the green was used as both ground and neutral.  This is a great illustration of why the code was changed from the three-conductor to the four-conductor cords: to separate the ground from neutral.  Read this post for more information:
http://applianceguru...2470&forum_id=2
#4 Pegi
Pegi
  • 13,120 posts
Posted 21 August 2005 - 09:41 AM
White on the middle terminal on the terminal block, red on the right and black on the left side and the green to the case where the ground attaches.
    Shōgun
  • 30,170 posts
Posted 21 August 2005 - 09:44 AM
Clarifying Note: Mangoman posted this same issue, nearly verbatim, twice: first as an unregistered user, which I replied to, then as a registered user, which Pegi replied to. For clarity, I've merged both threads together.
#6 Mangoman
Mangoman
  • 2 posts
Posted 21 August 2005 - 07:53 PM
pegi thank you very very much, thanks for helping the technology challenged masses
#7 Pegi
Pegi
  • 13,120 posts
Posted 22 August 2005 - 06:47 AM
LOL....you are quite welcome....:P
