Kenmore FL Washer No Spin
6 replies to this topic
#1 Adirondack Bob
Adirondack Bob
    Kohai
  • 304 posts
Posted 08 December 2009 - 04:16 PM
Greetings,   This is a Kenmore Front Load Washer
    Model:417.42052100    Serial XC24209291
(*replaced the Speed Control Board based on the following measurements but customer just called and said it is still not working*  )
The problem was no spin. I did the voltage measurements at the 6-pin and 10-pin plug as follows: START of heavy wash...pins 5-1=58.7 volts   pins 5-2=58.6 volts
pins 5-6=36.8 volts   pins 5-9=41.3 volts   pins 5-10=58.7 volts  I thought I did something wrong, so I spun the dial all the way around to the start of Heavy Wash and measured voltage again. this time I got... pins 5-1=50.4 volts   pins 5-2=117.3 volts   5-6=118.1 volts   5-9=50.2 volts   pins 5-10=118.5 volts
Measured resistance on 10-pin plug between pins 3 and 4=177.5ohms
Turn timer to Heavy Wash SPIN   pins 5-1=115.7    pins 5-2=115.5   pins 5-6=115.2
pins 5-9=115.1  pins 5-10=115.4   What could be wrong with this washer?
Thank You, Bob
#2 appl.tech.29501
appl.tech.29501
  • 8,027 posts
Posted 08 December 2009 - 04:48 PM
did you check the connections at both ends? What fault code was the machine showing? Maybe i am looking at the wrong manual, but the measurement that you did on the 10 pin connector between pins 3 and 4...was that the motor resistance 177 OHMS? If so motor is bad.
#3 Adirondack Bob
Adirondack Bob
    Kohai
  • 304 posts
Posted 08 December 2009 - 05:13 PM
Hi Thank You,  this is a Frigidaire washer.  Manual is "Tumble Action Washer with AC Drive"  There is no error code.  Page 52 of manual...the way I understood it is that if it read + or - 7 percent of 184 ohms bad speed control. it read 177.5 ohms. is that within range?
#4 RegUS_PatOff
  • Academy Instructor
  • 33,588 posts
Posted 09 December 2009 - 02:24 AM
[user=4576]Adirondack Bob[/user] wrote:
... The problem was no spin...
Does it Agitate/Wash/Tumble ?
417.42052100 Parts List
417.42052100 Tech Sheets   different Motor resistance tests ...
SERVICE MANUAL Tumble Action Washers With AC Drive motor
#5 Adirondack Bob
Adirondack Bob
    Kohai
  • 304 posts
Posted 09 December 2009 - 04:57 AM
Hi Reg, Yes the washer fills and agitates but does that slow tumble instead of spin. It goes through the whole cycle. The manual says "If between pin 5 to pins 2,6 and 10 read 110v and between pin 5 to pins 1 and 9 read less than 50vac, bad speed control."I did the voltage measurements at the 6-pin and 10-pin plug as follows: START of heavy wash...
pins 5-1=58.7 volts
pins 5-2=58.6 volts
pins 5-6=36.8 volts
pins 5-9=41.3 volts
pins 5-1=50.4 volts
5-6=118.1 volts
5-9=50.2 volts
 pins 5-1=115.7
pins 5-2=115.5
pins 5-6=115.2
pins 5-9=115.1
pins 5-10=115.4
#6 RegUS_PatOff
  • 33,588 posts
Posted 09 December 2009 - 06:40 AM
Is the Door Lock Light ON during Spin ?
Does the Door actually lock ?
While the Door is locked, un-plug Washer Power Cord from Wall Outlet.
Try opening the Door.
If the Door Latch is working correctly,
you shouldn't be able to open the Door for at least one minute.
check the voltages again..
pin 5 is ground, so no need to mention in the list of voltages ...
#7 NCSU_laundry_tech
NCSU_laundry_tech
    Senpai
  • Appliantologist
  • PipPipPipPip
  • 940 posts
Posted 09 December 2009 - 04:08 PM
"Does the Door actually lock ?
you shouldn't be able to open the Door for at least one minute."
turn it to drain/spin only for a couple mins, then turn off and try to open door. if it open immediately replace latch
To alcohol! The cause of... and solution to... all of life's problems.
