ftf2140es3 Frigidaire Washer
#1
Posted 08 December 2009 - 06:23 PM
I'm a stanger to self diagnostic machines, and miss the mechanical switches etc. I also miss figuring it out, so I wanted to run what I found out by you before I go and order the part.
So I get the call that this FreakyDare horizontal axis washer won't spin. It completes the wash and rinse, tumbling as it goes. Then it drains. Then it spins a few revolutions one way, stops and a few revolutions the other. Time for it to kick into the kind of high gear that makes you glad the door is locked, and......... nothing. No beeps or error codes either. It just announces "I'm THROUGH!" like a small child waiting to be wiped.
So I call up the error code by pressing START and Pause Cancel. I get an E46. (From the service manual: "E46 Control board problem. Replace the control board.") With four flashes on the row of lights and six on Start light. It doesn't automatically repeat, as the manual says it will, so I'm concerned that I'm not really seeing the correct code. I repeat the sequence a few times, and am fairly convinced, but nervous on ordering a new control board on the machine's say so.
Just to check, I try to run with the door open, and unlike the no spin problem the machine announces that there is a problem there and immediately gives the correct code without being asked. When recalled it does tell me "open door" and not Control Board problem, so now I believe the other diagnoisis even more, but why didn't it annouce a problem when there was no spin cycle?
Still doubting. Can you believe it? So I run a diagnostic test. In test postion 7, it fills and spins. In test postion 8, it drains then goes into high spin. So the spin works, so why will it tell it to spin in the diagnostic test, but not in the wash cycle and do I need the new control board? Main control board, right?
FYI:
FTF2140ES3 Parts List & Wiring Diagram
SERVICE MANUAL 3.0 Cu. Ft. HORIZONTAL AXIS WASHER GOOD & BETTER MODELS 11 MB
#2
Posted 08 December 2009 - 07:09 PM
#3
Posted 09 December 2009 - 01:14 AM
Yes, it would mean the control board, (Main CPU), not the motor control board.And this does mean the control board and not the motor control doesn't it?
But that is not your problem.
You have a bad wax motor in the door lock switch. The high speed spin working in diagnostics tells me this is your problem.
You may also be reading the error codes wrong, I did until I was set straight by all the other helpful and knowledgeable techs here. When you are counting the first number the second number is also being counted down in the other set of lights at the same time. If you notice when reading the code and counting the number of flashes for the row of 4 lights the single start light will flash at the same time, (that is a count of 4 plus how many ever more flashes after the row of 4 lights stop).
Take a look at these 4 discussions, others have walked the same path.
http://applianceguru...ic.php?id=18333
http://applianceguru...ic.php?id=15509
http://applianceguru...ic.php?id=18439
Eureka, CA 95501
#4
Posted 09 December 2009 - 01:18 AM
FTF2140ES3 Tech Sheets.. I get an E46. (From the service manual: "E46 Control board problem. Replace the control board.") With four flashes on the row of lights and six on Start light...
... and six on Start light...
is that a total of six on the Start Light ?
(including the Start Light flashes during the first four rows of lights)
#5
Posted 09 December 2009 - 02:38 AM
Yes. Both flash four times together, then the start light flashes two more times, for a total of six on the Start Light. So it is an E46. But that doesn't mean I have to believe the machine?
Tim
I thought not, that is why I kept messing with it.
I'm off to read the similar the similar posts on this. I guess these will tell me that it can give me a bad contol board code even if the control board is good.You have a bad wax motor in the door lock switch. The high speed spin working in diagnostics tells me this is your problem.
Back soon,
Tim
#6
Posted 09 December 2009 - 03:14 AM
Trying to find the part number for just the wax motor. Can you help? It's not listed.
#7
Posted 09 December 2009 - 03:16 AM
WPL 99001807 wax motor
http://www.repairclinic.com/SSPartDetail.aspx?s=t-99001807-%3d%3di752102&PartID=752102
WPL 12002535 Wax motor
http://www.repairclinic.com/SSPartDetail.aspx?s=t-12002535-%3d%3di1063620&PartID=1063620
from this post
The first one is $21 and the second is $12! Are they the same?
#8
Posted 09 December 2009 - 03:40 AM
So that's the little wax motor sticking right out the top isn't it.
#9
Posted 09 December 2009 - 03:44 AM
And, YES, that is the wax motor that you would need to replace, (the white part in the picture of the latch assembly).
These switch/latch assemblies open up real easy, just be careful to not snap the tabs off when opening it up.
Eureka, CA 95501
#10
Posted 09 December 2009 - 03:56 AM
You have saved me much embarrassment, and the client a good deal of money of the whole assembly. Why don't they list it separately as a part?
A donation to the fund will surely follow after the weekend.
#11
Posted 10 December 2009 - 01:44 AM
Probably because they wouldn't make as much money.Why don't they list it separately as a part?
They know this is a very common failure and if they listed the wax motor in the parts diagram as a separate part they wouldn't sale many of the complete switch assemblies, (I've only seen a coil in one of these switch assemblies fail once and never seen the switch contacts fail, seen more broken from someone forcing the door open when locked).
Eureka, CA 95501
#12
Posted 12 December 2009 - 03:44 PM
Thank you. This was very helpful. I took many photos, which I may add a write-up to someday. A successful repair, without an added visit.
$20 donation to the fund.
