SMW272S
2 replies to this topic
#1 kenpmgt
kenpmgt
    Ikkō-ikki
  • Chief Appliantologist
  • 30 posts
  • Flavorite Brew:Arnold Palmer
Posted 18 December 2009 - 06:17 PM
this is kinda a re-post
my turntable works only after i give a little spin. My question is: if the turntable does not spin the microwave shuts off after after about 4 seconds. is it normal to shut off for this model ? if it is, would the turntable motor need replacing so i don't have to give a little 3/4 spin.  Checked motor and is fine. would mis-alignment  of door locks maybe be the problem.  the door latches fine just trying to see why the turntable works every so often. Any ideas would be appreciated.
regards Kenpmgt
Ken
#2 appl.tech.29501
appl.tech.29501
  • 8,027 posts
Posted 19 December 2009 - 05:25 AM
If you have to manually start the turntable motor then is bad....it may test good without a load and fail with the turntable on it. You could have an intermittent door switch however I have never seen a unit stop because of the turntable...its more likely one of the door switches or their mounting brackets is faulty causing the unit to spuratically fail.
#3 kenpmgt
kenpmgt
    Ikkō-ikki
  • 30 posts
Posted 19 December 2009 - 06:49 AM
thanks for the advice, I'll give it a check........will advise
Ken
