Frigidaire FRS26DR7DS0
#1
Posted 26 December 2009 - 08:23 AM
#2
Posted 26 December 2009 - 08:32 AM
Is the Compressor running ?... I can see that the fan is working and everything sounds like it normally does ...
That model uses an Electronic Control Board
You may have to do some tests
Product Information and Technical Guide SxS & TM 1/04 - 6/04 # 5995413308
#3
Posted 26 December 2009 - 08:39 AM
#4
Posted 26 December 2009 - 08:43 AM
#5
Posted 26 December 2009 - 08:45 AM
You'd have to do some electrical tests using the diagrams in the above service manual.
#6
Posted 26 December 2009 - 08:52 AM
#7
Posted 26 December 2009 - 04:25 PM
#8
Posted 26 December 2009 - 04:32 PM
On Boxing day ??Well I broke down and had a service technician come and look at the fridge
#9
Posted 26 December 2009 - 04:53 PM
Second through fifth years from original purchase date:
Repair or replace any parts in the cabinet liner or Sealed Refrigeration System compressor,
(condenser, evaporator, drier and tubing) which prove to be defective in materials or workmanship.
#10
Posted 27 December 2009 - 02:01 AM
#11
Posted 27 December 2009 - 03:39 AM
.. is there a way that my defrost timer or thermostat is causing my compressor to run at half power?
Defrost Timer is an Electronic Control Board ...I also wondered if the compressor is need to run the water...
Compressor and Condenser Fan powered together ..
Does the Condenser Fan run OK ?
Water Dispenser is separate Electronic Controller
FRS26DR7DS0 Wiring Diagram
#12
Posted 27 December 2009 - 04:15 AM
#13
Posted 27 December 2009 - 05:49 AM
#14
Posted 27 December 2009 - 05:59 AM
www.eliteapplianceservice.org
#15
Posted 27 December 2009 - 07:35 AM
#16
Posted 27 December 2009 - 08:11 AM
the icemaker probably isnt working because the freezer isnt cold enough....the water issue is probably due to a bad water valve.
you most likely still have a sealed system problem so all this is just prolonging the inevitable.... just post back the temps.
#17
Posted 27 December 2009 - 08:22 AM
#18
Posted 27 December 2009 - 08:34 AM
#19
Posted 27 December 2009 - 08:39 AM
if you have a Harbor Freight Store near you
may be on sale at the store or in one of their current flyers ..
also 20% OFF coupon good till 1/29/10
also good on sale items
sometimes on sale... bring print-out to store
click on picture 96308 $ 12.99
click on picture 95683 $ 19.99
(on sale, but doesn't have many "low ranges")
click on picture 95652 $ 19.99
#20
Posted 27 December 2009 - 09:38 AM
