  • Announcements
ferrari
ge monogram oven zet837sb2ss
2 posts in this topic
I have a GE Monogram oven that the top of the door does not seal against the gasket at the top of the oven.Do you know if there is a adjustment for this?
this may apply to your model:
DOOR HINGE ADJUSTMENT:
To adjust the hinge assembly the oven must be pulled out of its installation by approximately 6".
This will allow access to the hinge mounting bracket.
(HINGE and MOUNTING BRACKET come as a COMPLETE ASSEMBLY).
One Assembly will be marked right and the other left.
To Adjust Hinge Assembly:
1. Mark the position of the hinge bracket on the side of the oven case.
2. Loosen mounting bracket screws (5) adjust hinge and retighten screws.
3. Check door seal.
Marking original position provides a guide for adjusting or replacing hinge.
NOTE: Hinge assemblies come as either left or right and marked on bracket.
Hinge can not be ordered separately.
NOTE: Hinge arm must be in the fully open position to service hinge assembly or to adjust / replace hinge arm micro switch (left assembly).
Always make sure switch is adjusted correctly
Oven light OFF when door is closed and oven in OFF mode
