GE Cooktop #JP939WHWW F153 error code
7 replies to this topic
#1 ChicagoDave
ChicagoDave
  • 5 posts
Posted 01 January 2010 - 04:50 PM
My GE Cooktop #JP939WHWW right front burner refuses to work and is flashing error code F153.  The other burners work fine.  I've shut-off the circuit and it didn't help.  I assume I need a new part - I am right?.  If so, what's it called/what's its number.  Thanks and all help is appreciated.
    Shōgun
  • Master Samurai Tech
  • 29,160 posts
Posted 01 January 2010 - 07:46 PM
Hmmm... not seeing an F153 error code in the mini-manual. Perhaps F173?
#3 RegUS_PatOff
  • Academy Instructor
  • 33,588 posts
Posted 01 January 2010 - 10:36 PM
1X31 Open temperature sensor (RTD)
1) X is the sensor number (1-5) as described in Figure 1.
    Shōgun
  • 29,160 posts
Posted 02 January 2010 - 04:59 AM
Ah, yes. Next time I'll pop in my glass eye so I can read the fine print. Domo. Reg!
#5 ChicagoDave
ChicagoDave
  • 5 posts
Posted 02 January 2010 - 07:06 AM
Okay, so I need a sensor: Can you tell me what the part number is?
#6 appl.tech.29501
appl.tech.29501
  • 8,025 posts
Posted 02 January 2010 - 07:50 AM
You cant just buy the sensor, you have to buy the entire element...if its the right font sensor you need then here"s your fix
element
www.eliteapplianceservice.org
#7 ChicagoDave
ChicagoDave
  • 5 posts
Posted 09 January 2010 - 08:53 AM
GE told me to "change the burner assembly" is that the same as the "radiant element"?
#8 appl.tech.29501
appl.tech.29501
  • 8,025 posts
Posted 09 January 2010 - 10:55 AM
Yes, the link I posted is for the radiant element assembly. Radiant is just the type of burner it is.
Make sure you check the wiring before you just plug the wires in the same location as the old one. The wire locations may have changed.
