Refrigerator GE PSS26PSTA SS
zeneczek
  • Replies 6
  • zeneczek
  • fcrawley
I have the service manual for the PSS23, 25, 27, 29
but the PSS26 is different ..
GE® imagination at work attachment.php?id=2760
  • 4 months later...
[user=60994]zeneczek[/user] wrote:
That I have .It's hard to get for PSS26.
I think he's saying he already has the  PSS25, 27. etc ..
and the  PSS26 is hard to get (if it exists)
all GE info is hard to get  :(
OK. I found print taped under
You mean you found the mini-manual taped under, behind the toe grill? That's about as good as it gets with the PSS26.
