Refrigerator
5 replies to this topic
#1 Guest_Mark_*
Guest_Mark_*
  • Lurking at the Threshold
Posted 19 April 2005 - 04:41 PM
I have a Kenmore refrigerator model # 106.9658114. Concentrated On the bottom center inside the refrigerator it freezes and also causes a puddle. It is cold enough that it freezes food. The temperature every where else in the refrigerator is normal. The freezer runs normal also. What could cause this?
#2 Jedi Appliance Guy
Jedi Appliance Guy
    Senpai
  • Chief Appliantologist
  • PipPipPipPip
  • 691 posts
Posted 19 April 2005 - 05:29 PM
Clogged drian could cause this.
  • 24,289 posts
Posted 19 April 2005 - 05:42 PM
Clearing a clogged condensate drain.
#4 Guest_mark_*
Guest_mark_*
Posted 11 May 2005 - 03:57 PM
I want to add that I checked the drain tube and that was clear. I did notice that on the top inside the refrigerator part that where the door is to direct more cold air to the freezer or refigerator that moisture drips from this and there is also ice. Certain types of food will freeze in the refrigerator part even though I turn down the temperature setting for the refrigerator
#5 Pegi
Pegi
  • 13,120 posts
Posted 11 May 2005 - 06:04 PM
[align=left]Sears does not make anything, they buy products from their venders and has the Kenmore name put on them.  This Ref. is a Whirlpool brand.  We cannot get any information from Sears about service pointers but we can get them from Whirlpool, who made this box.  I have no way of knowing if this service pointer pertains to your unit or not, but read this service pointer from Whirlpool to see if this is close to what you are seeing.  If this is not close please provide more details so we can see of there might be another service pointer or update to hep you solve this problem.  Pegi[/align]
[align=left]Refrigerators[/align]
[align=left]Moisture In Diffuser[/align]
[align=left][R-341 / 4321955 / Jan. 1996][/align]
[align=left]SxS COMPONENT HOOKUP DESIGN[/align]
[align=left]CONDITION:
Frost or ice forming in or around air diffuser.[/align]
[align=left]CAUSES:
Frost or ice formation is created by high moisture or humidity[/align]
[align=left]conditions inside the refrigerator and freezer compartments. The following may[/align]
[align=left]contribute to this condition:[/align]
[align=left]n
Possible blockage of return air openings.[/align]
[align=left]n
Leaking door seals.[/align]
[align=left]n
Cabinet leaks (particularly deck rail and corner gusset areas).[/align]
[align=left]n
The refrigerator is used in a warm and humid climate.[/align]
[align=left]n
Frequent door openings.[/align]
[align=left]n
Refrigerator loaded with uncovered food or food having high moisture content.[/align]
[align=left]Air diffuser frost or ice formation can be minimized or eliminated by doing the[/align]
[align=left]following:[/align]
[align=left]1. Clean air diffuser of frost or ice buildup.[/align]
[align=left]2. Check and correct any door gasket leaks.[/align]
[align=left]3. Seal the deck rail area (bottom front of cabinet) and corner gussets.[/align]
[align=left]4. Determine the product.s environment and consumer usage patterns. Inform consumer[/align]
[align=left]how these factors can contribute to excessive interior moisture and make[/align]
[align=left]recommendations on how to minimize interior moisture.[/align]
[align=left]5. Install Part No. 483166 Air Scoop Heater in air diffuser using kit instructions.[/align]
[align=left]6. Set freezer damper control to mid setting.[/align]
#6 exsearsguy
exsearsguy
    Kohai
  • 314 posts
Posted 11 May 2005 - 09:07 PM
Mark, make sure that your fridge is tilted back toward the wall. your drain is in the back of your box and water runs downhill. this won't help your freezing food problem,though.
