Whirlpool Duet GGW9250PW3
6 replies to this topic
#1 jrl
jrl
  • 4 posts
Posted 18 January 2010 - 02:19 PM
My Whirlpool Duet Gas dryer which is about 4 years old keeps shutting off prior to ending the cycle. my wife says the more she uses it the more chronic the problem becomes. I have verified and blown out the venting so it has good air flow. I read through some other posts and replaced the thermistor since that seemed to be the most common problem, but still no luck. Also sometimes it will run the whole cycle and the clothes are still not dry. PLEASE HELP.:shock:
#2 RegUS_PatOff
  • Academy Instructor
  • 33,588 posts
Posted 18 January 2010 - 03:54 PM
GGW9250PW3 Tech Sheets
#3 jrl
jrl
  • 4 posts
Posted 21 January 2010 - 02:02 AM
Can someone please advise on what you think the issue might be?  Thank you!
#4 RegUS_PatOff
  • 33,588 posts
Posted 21 January 2010 - 02:23 AM
The Motor stops OR the Display powers OFF ?
Is the Motor hot when it shuts OFF ?
Is this ONLY on the Auto Dry setting ?
Try it on the Timed Dry setting ..
check the Vent air temperature at the back of the Dryer
Sometimes on sale (bring print-out to store)
click on picture
#5 jrl
jrl
  • 4 posts
Posted 23 January 2010 - 08:59 AM
The Motor stops OR the Display powers OFF ? The display powers off.
Is the Motor hot when it shuts OFF ? Yes
Is this ONLY on the Auto Dry setting ? No timed also
Checked and it was 150 degrees. The vent is not blocked.
#6 jrl
jrl
  • 4 posts
Posted 26 January 2010 - 01:06 AM
Hi Any suggestions on what the problem could be?
    Shōgun
  • Master Samurai Tech
  • 30,371 posts
Posted 26 January 2010 - 07:01 AM
Here're some things to check:
- Run the dryer with the vent completely disconnected from the the back and see if it completes a cycle. Do this test first before anything else.
- If the dryer still shuts off, remove the toe panel, open the blower housing and check the fan blower wheel for build up of lint. Same with the filter housing.
- If problem persists, you'll need to see if the motor is still being supplied with voltage when it quits running. If it is, you have a bad motor.
