Tappan Gas Range Model TGF335BCWD
Bmartin39
Need both owners manual and service manual for this gas range. it is aging not so gracefully and the oven temp is 50 degrees off (too high) or more often overshoots setting.
Thank You
  • Replies 0
  • Bmartin39
