ExpressAppliance
GE Nautilus Dishwasher Model-GSD2625F00BB
4 posts in this topic
I own Express Appliance Service in New Jersey and I have a GE Dishwasher im having problems with. The unit will not drain and it wont fill although its already filled with water and all it wants to do is wash. I cant locate a schematic anywhere on the machine and im not sure what's causing this. I can tell you that no matter where the timer is I cant get 110 volts at the drain solenoid. I even moved the solenoid by hand and it wont drain. I feel there might be two problems. One that the solenoid wont activate and two that even when i move it by hand it still wont drain. I think i may be over thinking this job and would more than appreciate some help with this one. By the way my name is Rich.
If you remove the drain hose from the sink and lay it down will it drain? Sounds like your control may be bad as well, I will do some checking and post back.
I havent tried laying down the drain hose but it had drained just fine the first time I was at the home so i doubt it clogged up between now and then. I feel there has to be something wrong with the timer because not only will it not drain but it wont fill. I checked the float switch and there's no problem there as well as there is not enough water in the tub to trip the switch. I dont see any boards or sensors that could be a problem but like i said i have no schematic to go by. Thanks for any help you can offer.
Are you getting voltage to the valve during fill? I would agree that it sounds like the timer.
