GE washer/WJRE5500G2WW
7 replies to this topic
#1 GKOFC
GKOFC
  • Chief Appliantologist
  • 17 posts
  • Flavorite Brew:BUD
Posted 15 February 2010 - 06:47 AM
The mode shifter was replaced,and the first time customer used it ,it failed again.I put it into the test mode and it spun at hi speed,so am I looking at a bad part or a bad control?
Thank you.
    Shōgun
  • Master Samurai Tech
  • 30,211 posts
Posted 15 February 2010 - 07:00 AM
So it runs in test mode but not in a regular cycle? Sounds like could be either a control problem or a customer use problem.
Did you check the inverter board for the infamous 2-flashes error message? More info about these here:
http://fixitnow.com/...asher-wont-run/
And I PMed you the link for a service bulletin that may apply.
Service manual for this washer is in the repair manual stash.
#3 GKOFC
GKOFC
  • 17 posts
Posted 15 February 2010 - 08:09 AM
It spins in test mode,But in agitation it spins at the same time because the mode shifter is bad and will not pull gear up out of the way.The sheet says that if it spins fast in test vmode the motor,inverter and control are ok.
#4 appl.tech.29501
appl.tech.29501
  • 8,027 posts
Posted 15 February 2010 - 08:15 AM
After replacing the part did you reset the fault?
#5 GKOFC
GKOFC
  • 17 posts
Posted 15 February 2010 - 08:25 AM
Honestly I don't think I did,but I ran it repeatidly for about five loads and it washed and spun ok.
#6 GKOFC
GKOFC
  • 17 posts
Posted 16 February 2010 - 04:57 AM
Iwould just like to know what took out the new mode shifter,the motor/inverter or the control board?
#7 GKOFC
GKOFC
  • 17 posts
Posted 18 February 2010 - 09:38 AM
I found a GE update on this problem.It seems that my motor/inverter has to be replaced along with the mode shifter.It all depends on the part number on the motor/inverter unit.
blessings to all of you for your help.
    Shōgun
  • 30,211 posts
Posted 18 February 2010 - 11:17 AM
Domo for the update! Good one for the knowledge bank.
