Whirlpool RS675PXGQ2 oven temperature control will not go over 350F
5 replies to this topic
#1 chasehas
chasehas
  • 3 posts
Posted 17 February 2010 - 09:06 AM
Upon moving to a new house, I've discovered a very odd problem with the inherited Whirlpool oven. The "temp increase" button makes the displayed temp go down! Unfortunately, the temp decrease button also makes the temp go down...so right now, I can't cook above 350F (the default that appears when you press Bake). It's a Whirlpool model RS675PXGQ2 single oven, no drawer (I think, last few characters are smudged...and yes, I tried to rub it off). I've talked to Whirlpool, and they can only tell me that my oven was sold 10 years ago (so out of warranty) and that a service call will be required. Google tells me that others have the same problem [link], but no solutions have been posted. Apparently, however, it seems to occur after the oven runs through a self-cleaning cycle. I've tried cutting the power via the breaker overnight, with no luck. Any thoughts before I give up and call in the service guys?
#2 RegUS_PatOff
  • Academy Instructor
  • 33,588 posts
Posted 17 February 2010 - 09:51 AM
RS675PXGQ2
maybe
RS675PXGQ12    ?
#3 chasehas
chasehas
  • 3 posts
Posted 17 February 2010 - 01:18 PM
It may be 12 on the end...the last two characters are printed right on top of each other, I think. I've been staring at it for the last 5 minutes.
#4 appl.tech.29501
appl.tech.29501
  • 8,027 posts
Posted 17 February 2010 - 01:32 PM
Sounds like the control is bad...only repair is to replace it
#5 chasehas
chasehas
  • 3 posts
Posted 17 February 2010 - 01:44 PM
Ugh...that's what I've been trying to avoid, since it looks like a front panel assembly for this oven runs +$400.
Has anyone seen this problem before? I was hoping it was some kind of programming/logic issue, since it's a fairly unusual problem that multiple people have reported (which tends to eliminate my first hypothesis, dirty/sticky contacts).
#6 RegUS_PatOff
  • 33,588 posts
Posted 17 February 2010 - 03:40 PM
Electronic Controller  $ 164
click on picture
TouchPads  (may not be bad )
http://www.repairclinic.com/Appliance-Parts?s=t-RS675PXGQ12-%3d%3dc281
