battlepoint
Amana LW4303W washer leaks oil onto clothes, Fixable?
4 posts in this topic
I have an Amana LW4304W washing machine with stainless basket which just started leaking greas/oil onto clothes.  I assume the seals have failed and I now have water in the transmission and thus oil on my clothes.  Yes its oil.  I have it disassembled down to the hex nut and decided to ask to a little help.  Should I install a new seal kit ($50-$60).  Is the transmission damaged beyond repair by the water intrusion.  Is it possible and worth while to reassemble the transmission with new oil and seals.  My breakpoint is about $100 at which point I will buy something used to replace it.  I have read the thread titled "Amana Tub Seal Replacement "
Thanks Mike
Everything is fixable, it's just a matter of which battles you choose to fight. If it were me, I'd cut my losses on this pig and go get a front loader.
If I fill the rubber seal with silicon and then put it over the hex nut do you think I can keep the oil in the transmission and water out of the transmission for a couple of months until the transmissin seizes.  I will clean everything with degreaser before applying silicon.  What do you think?
If think, if you're lucky, you may get one or two loads out of it before it starts oozing again.
