Kenmore Power Miser 6 153.336811
lindadevlieg
:shock:
We are in a cabin in the woods with the above water heater.  Arrived to find we have no hot water.
Tried to re-light pilot and can't get pilot to keep lit....we are assuming it's that thermocople part, but want to find out....
as we are in a somewhat remote area with a couple of small town with small town parts stores around (no sears or lowes), will a universal part work on these?
State Industries Water Heater
Kenmore 153.336811  40 Gal Propane LP (High Altitude)
153.336811 Owners Manual  (lighting instructions page 18)
Thermocouple 42-9231
substitute H06E-036
looks like standard Thermocouple .. less than $ 10
Perfect!
Another beer on the way; it worked, we went to local hardware store and they had one left; 36 was a bit long but we just tucked it around and it's out of the way
