jch
Which horizontal-axis washers *don't* have a plastic outer tub??
10 posts in this topic
Interested in getting a horizontal-axis washer but am leery of the extra care-and-feeding of those that have a plastic outer tub.  The repeated stories of mold sound awful.
Are there any "mainstream" horizontal-axis washers that *don't* have a plastic outer tub??
Thanks!
.../j
You won't find hardly any washers, (top loader or front loader), that doesnt' have a plastic tub nowdays.
I believe the Stabler that Samurai swears by is metel outer tub. The stabler is kind of a hybrid machine, top loader but horizontal-axis washer.
[user=36]Budget Appliance Repair[/user] wrote:
You won't find hardly any washers, (top loader or front loader), that doesn't have a plastic tub nowdays.
I believe the Staber that Samurai swears by is metel outer tub. The stabler is kind of a hybrid machine, top loader but horizontal-axis washer.
Do you know whether *any* of the "mainstream" brands offer models with non-plastic outer tubs??  Siemens?  LG? Others??
I'm located in Canada.
Thanks!
.../j
What is there an echo in here? If you don't like Willie's answer, then make clarifying comments. Repeating yourself in a forum where your previous reply is still there for the reading is not only rude and obnoxious, but it does nothing to futher the conversation.
Will there be anything else, sir?
Sorry about that -- didn't mean to step on any toes... I didn't realize until after I posted it that I was using the same wording -- the system wouldn't let me edit it after I pressed Send.
I appreciate the quick response honourable leader :)
I am very interested in the Staber, primarily because of:
  • its all-metal construction (to prevent mold growth), and
  • its user-servicability.
but the following issues have made me want to consider other options:
  • delivery costs here in Canada make the Staber very expensive :(
  • I keep reading postings commenting on how noisy it is (it would be right below our young kids' bedrooms)
  • I'm also concerned about the delivery time for replacement parts since it appears that you have to order direct from the US Factory whenever a problem arises (i.e. no local parts inventory).  User-servicibility is great, but not if it puts the washer out-of-commission for a couple of weeks while the parts clear customs
  • it doesn't include a water-heater (we keep our main water heater at a low setting to avoid scalding little hands) so would like a temperature-boost in the machine itself
  • its capacity is ~30% smaller than other horz-axis machines
  • its MEF rating (i.e. how dry it spins the clothes) is 20% less than other horz-axis machines, probably because of its lower spin speed.
Are there any other non-plastic models available?
Appreciate the help,
.../j
In the F/L models I really can't think of any that don't have a plastic tub now. (I don't know anything about the LG brand but kind of suspect they are plastic also, someone else can probably confirm that.)
The only top loader that I can think of is the REAL MAYTAG Dependable care machine (I believe) still has a steel outer tub.
Other than that I can't help you any further, sorry....
Looked in the LG site yesterday and a photo of the rear area of the washer looks to have a white plastic tub in there, however we have not had any mold problems reported yet.  Have to leave doors/lids open, use hot water and bleach now and then to help with this problem, but some washers like the Neptune are beyond helping.  Wiping the boot dry after each days use would help.
Speed Queen/Huebsch, Miele and Asko as well as Staber have H-axis washers with both stainless steel inner and outer
tubs.
Thanks for all your help so far--this gives me some great leads to follow-up on.
I'll post if I find any other non-plastic machines.
.../j
