sears spin problem
2 replies to this topic
#1 sox771
sox771
  • 12 posts
Posted 11 March 2010 - 03:24 AM
sears # 110.28042700 top load washer, sipn problem, when i put this into a automatic diagnostic mode i get a code f44 at step c5. cannot find what code f44 means. the spin problem only happens once in a while, i have changed the control board with no change. the rps check out ok.  any help would be great
#2 RegUS_PatOff
  • Academy Instructor
  • 33,588 posts
Posted 11 March 2010 - 03:54 AM
[user=47835]sox771[/user] wrote:
... i get a code f44 at step c5. cannot find what code f44 means...
110.28042700:
(no Heater)
step C5 Heater turns on for 5 seconds.
N/A (Applies to heater models only)
models with Heater:
F44 Heater cannot be turned ON
F then 44 flashes when the heater has been turned ON by the control,
but the control cannot detect that the heater is ON.
    Shōgun
  • Master Samurai Tech
  • 31,221 posts
Posted 11 March 2010 - 03:57 AM
When you get the no spin problem, had the tub pumped out all the way? I've seen intermittent bad pumps on these washers that will drive you insane.
