everything but duct tape
6 replies to this topic
#1 BrntToast
BrntToast
    fellow,academy of sublime masters of appliantology
  • 1,215 posts
  • Flavorite Brew:i quit drinking the day i woke up nude on the hood of my car with my keys up my butt
Posted 12 March 2010 - 06:17 PM
i recently had a call for a noisey GE dryer
and yup... it was one of those noises that made me say "holy shit!" and yank the door open to stop it
once dismantled i first noted that the glides were gone and the plastic bearing they mount to was worn through in spots. but.... this had been repaired, by attaching self adhesive felt strips like you paste to the bottom of chair legs to prevent floor scrathes. and this surely wasn't the noise i had heard
after drum removal i found.... the wrong motor installed, the one in the machine was too short to reach the rear clamp. but this had been solved by.... a section of rubber floor mat from a car rolled up, which was secured to the motor by 2 hose clamps joined togeather, other end of mat had extra rubber rolled over it to make a snug fit for the clamp
noise was motor flexing and bashing into bottom of drum
you would think this is where it ends....  NOT!
element had a repair... about 3 insulators worth of coil where stretched straight to extend it, this coil wire had been run through the terminal block and mareted directly to its wire
this was a rental and a new tenant that was complaining about the noise, so god only knows how long this abortion had been in use before the new tenant
The only stupid question is the one not asked
hope i've been helpfull, if you wish to buy Brnt beer kick here
http://brnttoast.googlepages.com/home
feel free to prvt msg frigidaire questions my way
(i dont log in every day)
#2 ROBBYRIG
ROBBYRIG
    Senpai
  • PipPipPipPip
  • 635 posts
Posted 13 March 2010 - 03:23 AM
WOW!!
The guy that did that must've been some sort of genius, albeit a dangerous one. That's some sort of skill to adapt the wrong motor to work on that machine!!
#3 appl.tech.29501
appl.tech.29501
  • 8,019 posts
Posted 13 March 2010 - 03:28 AM
Should have snapped a picture of that 1.
I had a Whirlpool dryer the other day that ran and sounded half way decent. I took it apart and couldn't believe my eyes. This was an extra capacity top filter dryer. There was no rear felt strip on the back of the drum, somehow it was in the center of the drum under the belt. After scrathcin ma head and doing some PI work I concluded that someone had taken a frigidaire belt and tried to install it but it was too long so they got a rear felt strip off a front filter dryer and installed it on the drum which fit nice and tight and then put the belt in the center of it and did away with the idler pulley and hooked the belt directly to the motor. Someone put some real thought into this rig..I was slightly impressed.
www.eliteapplianceservice.org
  • 24,692 posts
Posted 13 March 2010 - 04:50 AM
Woulda loved to feast my Samurai squinties on that one!
#5 BrntToast
BrntToast
  • 1,215 posts
Posted 14 March 2010 - 05:24 AM
the picture i would have loved to have seen was an old GE dryer that had worn away its glides, so the worn glides had been replaced with....  the rear wheels from a shopping cart
one of our other techs saw this and said the machine ran great and he actually replaced the belt on the unit
<shrug>
#6 appl.tech.29501
appl.tech.29501
  • 8,019 posts
Posted 14 March 2010 - 06:37 AM
Gotta keep my eyes on yu Canadians ;) I once played in a band with a guy from Manitoba... he powered all the lights in his house with his car battery. I miss that dude.
#7 kdog
    RoughShod
  • 7,433 posts
Posted 14 March 2010 - 07:46 AM
We goy a guy named Gilligan runnin' the pedals on our nations main transformer!
