goran59
panel removal sub zero 561
2 posts in this topic
I'm replacing the sensor control on my sub zero 561 and need info on how to remove the rear interior panel ...that prevents access.
Remove the light lens, remove the three screws holding the evaporator motor/fan grill,   there should be two screws, one in each upper corners ...tip the panel forwards...you can remove the cold controls now if you want ( remove the dials first )  duct tape the cold controls to the rear wall..... Remove power first........................ this is for the fresh food side ........
