service manual for gshl6phxcels ge sxs refrig
kjr232
I AM IN NEED OF A SERVICE MANUAL OR ANY TECH BULLETINS FOR A GE REFRIG MODEL GSHL6PHXCELS SXS. I HAVE LOOKED THRU THE AVAIL ONES BUT AM NOT SURE IF ANY ARE AVAIL. THANKS KJR32
  • Replies 7
  • kjr232
what problem area are you looking for ?
this one may be similar ..
GE GSS Models SxS Refrigerators Service Manual
THE ELECTRONIC READOUT ON THE FREEZER DOOR IS ERATICALLY SHOWING ALL ZEROS AND THEN THE BUTTONS WONT WORK. IS CCOLING FINE
Sounds like a loose or oxidized wire harness connector. Disconnect/reconnect all the wires and harnesses going to the control panel. Also, check that harness connector at bottom hinge of the freezer door.
YES THAT WAS IT. THANK YOU FOR ENLIGHTENING ME WITH YOUR ULTIMATE WISDOM. FOR THAT YOU SHALL RECEIVE A BEER.
Which was it: bad connection at the board or at the freezer hinge?
Nice job! :coolblast:
