GE PROFILE
9 replies to this topic
#1 Guest_GaryB_*
Guest_GaryB_*
  • Lurking at the Threshold
Posted 20 April 2005 - 01:58 PM
GE Profile range. Model #JGBP85BEB5BB..  The touchpad will let you put in the numbers to bake at, but the start button will not work.  Does this sound like the touchpad or the ERC.  I have part numbers for both, but no real appliance repair experience.  Any ideas would be appreciated.
Gary
#2 The Seven
The Seven
    Sōhei
  • Master Appliantologist
  • 190 posts
Posted 20 April 2005 - 05:45 PM
Could you use the touchpad to input other function?
If no, most likely touchpad is bad.
If yes, most likely ERC is bad.
The Seven
#3 GaryB
GaryB
  • 4 posts
Posted 20 April 2005 - 06:25 PM
The touchpad has all the # keys, and they all worked, the Bake and Broil key workey.. All keys worked except the start key.  We put something in the oven, select bake, 350 and hit start, nothing happens.. It then flashes push start and I think it beeped.  Do you still think its the touchpad.  Thanks for the advice
G
#4 GaryB
GaryB
  • 4 posts
Posted 20 April 2005 - 06:28 PM
Can just one key on a touchpad go bad, or generally does the whole thing crap out at once?
G
#5 Jedi Appliance Guy
Jedi Appliance Guy
    Senpai
  • Chief Appliantologist
  • PipPipPipPip
  • 691 posts
Posted 20 April 2005 - 06:48 PM
Before you do anything else turn off the breaker to it for a few minutes.  Turn it back and and try it.
Anything is possible.  If that doesn't work, turn off the power, remove the 4 1/4 inch screws, remove the console and let it hang by the wires.  Remove the door if it gets in your way.  Read the tech sheet taped to the inside to your left.
If you stare at it long enough, sooner or later the light bulb will go off in your head and you'll know which pins on your ERC near your ribbon cable you need to jump out to simulate pressing the start button.  If you do this and it comes on then it can't be the ERC.
You said the start button doesn't start the bake or broil.  Does it work on the clock, the timer, or clean?
#6 GaryB
GaryB
  • 4 posts
Posted 20 April 2005 - 07:10 PM
I already had it all pulled apart.  It was unplugged, Reassembled and plugged in, the start key does not work for anything.  From what you said sounds like I may need a new touchpad.
G
#7 The Seven
The Seven
    Sōhei
  • 190 posts
Posted 20 April 2005 - 07:43 PM
Each key is a switch. It is very unlikely that all switches fail at the same time!
More "press"! More "wear"!
START answer please!
Which key the user press most?
Then follow Jedi's FORCE to check START.
The Seven
#8 GaryB
GaryB
  • 4 posts
Posted 20 April 2005 - 09:41 PM
Allright,  I looked at the schematic and figured out witch ones to jump.  I plugged it all in and selected bake, 350 and was able to start the oven...  Looks like a bad start switch, and the ERC is OK.  You guys ROCK. Thanks for the info
:banana: G
#9 Guest_Grandpa9_*
Guest_Grandpa9_*
Posted 17 October 2007 - 02:04 AM
I have a problem similar to Gary's (April 05).  Ge Profile double electric oven.  Showed failure code F7.  Removed panel, diconnected and cleaned all connections.  Reassembled.  Now the START and CLEAR buttons (top and bottom) don't work.  There was no "tech sheet" in my oven.  Do you know where I can get one?  Thanks.
#10 Poobah
Poobah
  • 1,485 posts
Posted 17 October 2007 - 07:21 AM
from the Samurai (Master)...info on a F7
This is the DAY that the LORD has made, REJOICE and be glad in it.....
