R134A Question
citizenX
Ok, I should probably know this but what is the real difference and/or risk in using automotive grade R134a for appliance use? I know the appliance grade stuff is tested for purity and dryness beyond that of automotive grade but would the system hold up in the long run for domestic appliances? I'm 608 certified and was always taught since the beginning to use appliance grade r134a (and I do) but I hear of others using automotive grade and wondered if anyone here does it or has any insights. Is it worth saving a few bucks to buy auto grade?
Thanks
Brian
  • Replies 9
I have used a 30 gal jug of R134a at work and I have used cheap cans from the dollar store on refrigerators and freezers.  Never had a problem.  In fact I never even thought their is a difference in the 2 until you asked this question.
Well there is most definately a difference in the two...automotive grade is not manufactured to be as "clean" or dry as appliance grade therefore that is why it is generally cheaper than appliance grade. I find that many folks are using auto grade for everything - either because of cost or just because they don't know there is a difference.  As you know, automotive systems don't have compressor windings and extremely narrow capillary lines to contend with as in sealed refrigeration systems so the auto refrigerant doesn't need to be as pure as it is does with appliances. I've used nothing but appliance grade since 1995 but I was just wondering if anyone had any long term issues (burnouts, clogged cap lines & driers, etc) with using the auto grade in appliances. I guess I'm trying to discern if there really is that much of a difference to the extent that I've been taught and followed all these years.
There is a difference as you say., the auto grade isn't as pure...I have seen both used in refrigeration applications with no problems. As long as your using a good auto grade brand (some of the small 1lb. Cans that are china made have extra oil to get the weight up to the 1lb. Mark.) I don't think you will ever have a problem using it in refridgerators....the sad truth is the sealed systems aren't designed to last long enough for the long term problems (if there are any) to become a factor.
I would sure have to agree with you on that statement appl.tech.29501!!!!!
From what I've been seeing lately and especially in your favorite brand, (for the life of me I can't figure out why), Frigidaire, I say you're lucky if you get 9 years out of any of this new junk on the market.
I've seen so many 5 - 7 year old Frigidaires  with sealed system problems it's not even funny.
Willie I'm a Whirlpool man when it comes to refridgerator.... the only Frigidaire appliance I am partial to is there dishwashers. You couldn't give me a frigidaire refridgerator. Their sealed systems are by far the worse on the market....hmmm I might need to write a Haiku for that 1.
I see you always raving about there dishwashers and I don't see how that can be.
I thank they are some of the worst built dishwashers around.  I've seen plenty of wash motors going out on these pieces of junk and don't get me started on their lower rack rollers constantly falling off and door latch handles breaking!!!!!!
I've noticed also in the last year or two Frigidaire is going they way of G.E. in part prices, (2 to 3 times higher then any other manufactures for the exact same part), just like G.E. has always been.
All brands have their issues, guess when it comes to dishwashers I have just had better luck with frigidaire, and yes prices are on the rise.
I agree with Frigidaire being the worst dishwasher around, but I am having more issues with old school Amana SXS refrigerators having sealed system issues, mostly evaporator refrigerant leaks.
yeah Scott me too its a close race between the Amana's and the Frigidaires at the moment.
