dryer is on fire
  • This topic is locked This topic is locked
24 replies to this topic
#21 mopar X
mopar X
    Yamabushi
  • Master Appliantologist
  • 76 posts
Posted 23 April 2005 - 02:50 PM
[user=307]burn_me_once[/user] wrote:
because the discoloration was present in the back of the machine to start I also now believe it is possible that the excessive heat warped the plastic support of the rear drum bearing causing the loud noise. Is this possible?
See My last post also get a thermometer and measure temp out of dryer should be close to thermostat setting . Did you recheck to see if you disturbed blower seal ?? get the kit i gave you in last post install it and that will help excessive heat on back just might solve your problem also let us know
#22 burn_me_once
burn_me_once
  • 8 posts
Posted 24 April 2005 - 10:23 AM
model # is DVL223ea0ww  I probably put an o where zero is sorry about that.  I have used this number to obtain the rear drum bearing assembly
#23 Samurai Appliance Repair Man
  • 24,694 posts
Posted 25 April 2005 - 11:15 AM
Mopar, either your posts are invisible or Burn_me_once is ignoring them.  :huh:
#24 mopar X
mopar X
    Yamabushi
  • 76 posts
Posted 25 April 2005 - 11:45 AM
I Need to be more FORCEful in answering
#25 mopar X
mopar X
    Yamabushi
  • 76 posts
i sort of thought that:banana:
