leyengt
GE Refrigerator Door Dispenser stuck on!
7 posts in this topic
Our 4 year-old GE side-by-side refrigerator, model GSH25KGMB BB, began dispensing ice all by itself this afternoon.  My son had used it a few minutes before for ice cubes, but no one was near it when it just turned itself on.
After messing with the ice maker on/off switch (behind the upper shelf), the door switch (on the top inside of the freezer) and all the door switches (water, crushed ice, regular ice, etc.), I finally got it to stop by activating the child lock function.  I tried unlocking it hoping it would reset, but no joy - once again here comes the ice.
Best I can figure, the system “thinks” the dispenser switch is being pushed by the paddle that you press your cup against to get ice or water.  That paddle is swinging freely and I can hear the “click” of the switch as I push and release it.
 If there’s a way to access the switch I’d appreciate knowing how to try – I can’t find any access from inside the unit and I tried to pry of the bezel around the dispenser from the outside but got concerned I’d break it since it didn’t come easily.
Any ideas are certainly welcome!
Check the micro switches, esp. item 72, make sure they're not stuck. If they check out , then you're left with replacing the control board (item 90). -- it's a common troublemaker on this fridge. CLICK HERE.
Thanks for the advice and diagram. I was able to clean the corrosion mess off the contacts of the micro switch with a file and things seem to be working OK now.
Funny, it seems that the micro switch is normally closed so any disruption causes the circuit to open and the ice falls out like a slot machine. I would seem to make more sense to have the circuit closed when the micro switch is activated.
Like you also mentioned, this will be our last GE appliance. We've had five service calls plus this event in four years and that just seems wrong. Live and learn.
You will need to see if your frig falls under this moisture repair program by your serial number.
http://www.keyprestige.com/GE/SxSMoisture.pdf
Here is the updated serial numbers that were added....your model number is in this program.
[align=left]Important Change to 4th Year Moisture Program On any service call for any failure on the listed models/serial numbers, please call customer relations once the diagnosis is complete at 1-800-437-9283, prompt 1. The serial number range on the affected models has been expanded to include all serial numbers from AA2-ZD2. [/align]
Nice work!
Actually, the story gets even better.  Based of the information Pegi supplied, I called GE on Thursday and asked for coverage under their moisture program since we had three service calls in 2003 due to similar problems.  Even though our unit is just over 4 years old, the serviceman that came out this morning agreed that this is a moisture problem and two new doors will be provided and installed free of charge.  There was also no charge for today's service call.
The new doors are thicker, evidently due to different and thicker installation according to the service technician.
Again, hat's off to you all for helping me through this.  It will be great to have this problem finally solved.
Greg
Cool,  pleased I was able to provide the information you needed to get this repaired for good and for free. You reply will give hope to others that they can get Big Companys to do the right thing for their customers..:cool:
