GE Model #WCVH6800J0WW Front Loader dancing.
12 replies to this topic
#1 Volkemon
Volkemon
    Sōhei
  • Appliantologist
  • 111 posts
  • Flavorite Brew:IceHouse
Posted 20 April 2010 - 05:02 AM
Greetings!
One of our residents has a front loader with a shaking problem. Worst on towel loads, little or no shakes with lighter loads. At the final drain/spin stage, it starts at 7 min, rotates seveal times to distribute the load, then spins  little faster. Starts to clunk and bump, then slows and stops. Does the tumble/distribute routine again. Repeats this 3-5 times, then finally spins. The first time, shaking and never semed to get to top speed on the spin. Counts down 4 min to off as it spins. Checking the towels, they are still rather damp.
Put them back in for a 'drain and spin' cycle. Starts at 12 min, works its way down to 9 min, all the time tumbling the towels, then spinning just fast enough to keep the towels from falling. Attempting to go faster, it thumps,bumpsand stops. Then back to the slow tumble and 12 min. Did this 3 times, then seemed to 'find its balance' and get pat 8 min and start to really spin. THIS time it gets into 'high gear' on the spin, and water is seen coming out of the towels. NOW when they are removed, they are almost dry.
Ran washer empty and to establish there was no problem empty- smooth as silk.
Machine was installed 6/10/08 and does 10 loads a week +/-.  Passed all diagnostic tests just fine. I am leaning towards new shocks for it, but at $200 for the set of 4... I wanted to consult the dojo.
Thanks!
Onward and Upward!
    Shōgun
  • Master Samurai Tech
  • 29,808 posts
Posted 20 April 2010 - 10:54 AM
Watch this and lemme know whacha stank.
#3 Volkemon
Volkemon
    Sōhei
  • Appliantologist
  • 111 posts
Posted 20 April 2010 - 01:41 PM
Ahh..... I had not considered that. :touched:
It was MUCH more fun to consider much more complex and expensive solutions. (NOT!!)
Tomorrow I go to adjust. I will report back.
DOMO ARIGATO!!!
Onward and Upward!
#4 Volkemon
Volkemon
    Sōhei
  • Appliantologist
  • 111 posts
Posted 21 April 2010 - 09:30 AM
Oh well...no that easy. Level, legs tight, and all shipping bolts removed.
Any other suggestions, or reasons maybe on why NOT to buy shocks?
Thanks again.
Onward and Upward!
    Shōgun
  • 29,808 posts
Posted 21 April 2010 - 06:15 PM
The more common causes are:
- loose pulley (assessed directly-- grab 'hold an wiggle)
- bad bearing (assessed visually-- usually leaves gookus stain around the bearing)
- broken drum support spider (assessed directly-- excessive slop and play in inner basket)
#6 Dan Webster
Dan Webster
    Paw Paw
  • 1,327 posts
  • Flavorite Brew:Busch
Posted 21 April 2010 - 06:44 PM
http://appliancejunk.com/ge/washer/31-9135.pdf
Page 46
"May the hinges of our friendship never grow rusty"
-old Irish saying
Buy me a Beer: http://web.me.com/ze...man18007260692/
#7 Volkemon
Volkemon
    Sōhei
  • Appliantologist
  • 111 posts
Posted 22 April 2010 - 03:09 AM
@Grand Fermented Master-
Would not all these problems be evident with no load, or any load? I will check all, however. THANKS! (And did you expand the repair manual section? I dont remember sooooo many GE tech manuals!)
@applianceman18007260692- THANKS! But what does 'front banger' mean in this context?
I am going to check the items offered by The Master, but order shocks today. I will post results.
Onward and Upward!
    Shōgun
  • 29,808 posts
Posted 22 April 2010 - 03:13 AM
It's a never-ending work in progress. Always trying to add more value for my subscribers! :dude:
#9 Dan Webster
Dan Webster
    Paw Paw
  • 1,327 posts
Posted 22 April 2010 - 06:40 AM
It's is my endearment to front loading machines. LOL
A lot of folks will agree with the analogy.
-old Irish saying
#10 denrayr
denrayr
  • 1,134 posts
Posted 22 April 2010 - 08:04 AM
how many towels are they putting in? i have this washer and can speak from experience that it does not like to be overloaded. Generally, i load dry towels loosely until they fill about 75% of the basket. One more towel than this and the machine will struggle to balance the load.
RedRock Appliance Service
435-773-7838
www.redrockrepair.com
Serving St George and Southern Utah
#11 denrayr
denrayr
  • 1,134 posts
Posted 22 April 2010 - 08:08 AM
one more thing. unless the dampers show signs of leaking oil, are physically broken, or the tub sits excessively low with a full load, they are good.
435-773-7838
#12 Volkemon
Volkemon
    Sōhei
  • Appliantologist
  • 111 posts
Posted 22 April 2010 - 09:24 AM
@denrayr- Many thanks. I saw the load after it was wet, and it didn't seem too excessive (size wise). I will meet with the homeowner again.
On the condition of the shocks- I have yet to put an eyeball on them. My auto repair experience led me to think that they were worn, due to lack of any other cause.
I will keep this post current until resolved. Thanks again for the help, y'all!
THANKS! A physical inspection will be made before purchase.
Onward and Upward!
#13 Volkemon
Volkemon
    Sōhei
  • Appliantologist
  • 111 posts
Posted 27 May 2010 - 04:31 AM
Well, Finally got the shocks in and installed.
@denrayr - these shocks are a dry friction type, no oil charge to leak.
The old shocks were not that bad. Even the new ones seem to have a 1" or so 'slop' before they catch and dampen.
But when a 3-star retired general says 'Do Something' you replace something!
Here's hoping... I will post if I hear anything more.
Onward and Upward!
