officer
F3 code on Kenmore Oven
8 posts in this topic
Samurai
I have a problem with my Kenmore wall oven.  Model # 911.3042993. It flashes a F3 code.  I have already replaced the oven sensor.  I have checked the wiring from the oven sensor to the ERC.  They appear to look fine.  This oven has 3 thermal switches:  A fan thermal switch (purple dot) that controls the mixing fan.  A fan thermal switch (white dot) that controls the cooling fan. Then finally a lock circuit thermal switch (yellow dot).  I am not sure how to check these switches.  I have the technical data sheet for this oven.  The F3 code states this:  Open sensor circuit.  1. Measure
Sensor Circuit Resistance at sensor/Lock switch connect plug at ERC.  If I replaced the oven sensor do I still need to do this?  There are a few more suggestions on the data sheet but they all point to the oven sensor.
I appreciate any help you can give me.
If you used the original plug in connectors they sometimes make bad connections, it is advised to cut the wires and splice with ceramic wire nuts, might try this to see if this error is still there. Also did you turn the breaker off and back on to reset the ERC?
I cut the wires and put wire nuts on the new oven sensor and taped them up w/ electrical tape.
I also reset the breaker still have the F3 code.
It only happens when it is cooling down.
[user=3234]officer[/user] wrote:
The F3 code states this: Open sensor circuit. 1. Measure Sensor Circuit Resistance at sensor/Lock switch connect plug at ERC. If I replaced the oven sensor do I still need to do this?
Hello, my open sensor friend. Yes, you should still measure the resistance of the sensor circuit from the ERC since your problem points to something amiss in that circuit.
Would you be so kind as to post those? Perhaps we could glean a hint of something else to examine by reading the suggestions in the tech sheet. Better yet, you can post a copy of your tech sheet here as an attachment.
ERC Failure Codes: F3-Open Sensor Circuit
1. Measure sensor circuit resistance at sensor/lock switch connect plug at ERC (Should be approx. 1100 Ohms @ room temp.).
If Circuit Open look for:
*Open Sensor-measure directly across sensor (pull sensor into oven approx. 10 ines for access to sensor disconnect).
*Cut or pinched sensor harness wire.
*Melted sensor disconnect-sensor disconnect (behind oven) will melt during self-clean if connector is improperly positioned against oven cavity.
* Loss of contact within sensor harness connectors at back of oven or at ERC.
*One or both sensor leads shorted to ground.
Sorry I dont have any way of posting the whole data sheet.
Yep, everything points to the sensor. There's no getting around doing that resistance measurement from sensor connector at the ERC. Make that measurement and report it here.
Did you use ceramic wire nuts or plastic ones? Have you re-visitied these splices since having the problem again?
I put the wire nuts that came with the new sensor on.  I cant remember if they were plastic or ceramic.  I have to wait on my friend to come back and help me pull the stove back out before I can get a reading on the ERC.
What about the thermal switches do you think they might be a problem?
I have no reason to suspect them-- everything points to a problem with the sensor circuit.
