drumhopper
Cold things warm and frozen things warmer
7 posts in this topic
My refrigerator has decided to do the warm thing. It started as a single incident in which I thought would be resolved by removing 2 inches of cat fur from the condensor and vents. But alas, a few days later it went back to doing the warm thing. After believing that the freezer was simply too full and cleaning it out (because most of it went bad), the thing cooled once again. However, it more frequently goes to it's warm ways. Now a technition is called and orders a new defrost switch which as of yet has not arrived.
Now knowing to turn the defrost switch I have found that this really has no effect. The fan runs, but I am not sure if the compressor is actually doing anything. I am now to the point where a 50 degree fridge is the best I get, ever. This machine can't be more than 6 or 7 years old.
Is this machine repairable (and how?) or do I start looking for new features?
Hello, my warmed-over friend.
Undoubtedly, your refrigerator is repairable. I suggest you begin by removing the back wall inside the freezer to ascertain whether or not the evaporator has frozen over like so much Hell.
This morning I awoke to the surprise that the machine cooled last night. So next I checked the condenser and indeed some of my hell had frozen over. After I chipped away all the ice and thawed it, I restarted the fridge.
Now, however, it seems that it is holding a grudge and will not turn on more than the fan again.
I am hoping for a new cold control to arrive today. I don't have any idea if it will do the trick, however.
What should I try next?
If freezing coils is the problem, how do I keep it from happening again?
Thanks for your help!!
Once again my fridge is going on with it's indecisive ways of cooling. I've defrosted the ice that formed mostly around the wire harness at the top of the evaporator. I also replace the control that regulates the temperature in the freezer.
Now, once again all is thawing and I'm out of ideas. What could be causing this intermittent warming and thawing? It acts like the thermostat isn't working properly, but I think I just replaced that.
***Once again my fridge is going on with it's indecisive ways of cooling. I've defrosted the ice that formed mostly around the wire harness at the top of the evaporator****   ????  The whole evaperator should be frosted, not just ice at the top....this sounds more like a sealed system problem.  Can you please post the brand and model number in here and the age of the frig.
The model is an Amana SQD26VW and was made in 1999.
Talking to a friend who does maint. for a living, he thought maybe a coolant leak. Perhaps that or a bad defrost timer?
We can keep the fridge cold by manually defrosting the system a couple times a day so the compressor will cool the system again. But the freezer has to thaw each time, so we know it isn't working and we play with the defrost timer again.
I don't know what to try next. Any ideas?
Thanks!!
