robertalanathome
Amana dishwasher ADU6000D72WW
4 posts in this topic
My dishwasher usually pumps out prior to fill with water.  Instead it starts with the wash and no water.  I can hear the motor run at the same time.
Advancing the timer does not change anything.
May I ask for your assistance?
Thanks in advance for your support!
Bob
Timer gives power to the fill valve thru the flood switch, see if the flood bubble is stuck up, cutting the voltage to the water valve.  You could have a valve that has gone bad, lost the water supply to this valve, the flood switch could have gone ka-poot or no power to the switch from the timer.  Start with the flood switch and the water valve.
Thanks for the suggestions.
May I ask how to check out these parts?  I repaired washers in the past but never worked on a dishwasher.
Thanks for your support!
Bob
