Built in oven malfunction PLEASE HELP!
9 replies to this topic
#1 taylor97
taylor97
  • 5 posts
Posted 21 April 2005 - 06:00 AM
I have a GE Electric Convenction built-in oven model #JTP18COD1CC
The display beeps for several minutes and then displays "F7" & all functions become locked/disabled. I followed the troubleshooting tips & disconnected all power and then reconnected with the same problem. Any suggestions? THANKS in advance
#2 mopar X
mopar X
    Yamabushi
  • Master Appliantologist
  • 76 posts
Posted 21 April 2005 - 06:34 AM
Replace touchpad and control board
#3 taylor97
taylor97
  • 5 posts
Posted 21 April 2005 - 07:22 AM
Thanks for the advice, but I imagine it is one or the other, how do I know if I should replace the ERC or the touchpad?
  • 24,677 posts
Posted 21 April 2005 - 07:29 AM
You can apply my proprietary component isolation technique:geek:
#5 taylor97
taylor97
  • 5 posts
Posted 21 April 2005 - 07:39 AM
Thanks for your help, a couple more questions before I try this.  As I am somewhat handy, so I hope I can do this myself without calling out repair service.
1.  Is there a way to cut the power to the range besides the circuit breaker?
2.  What will the ribbon connector look like that needs to be disconnected?
3.  I assume to get to the ERC, I just start unscrewing parts from the touchpad?
Thanks again:)
#6 The Seven
The Seven
    Sōhei
  • 190 posts
Posted 21 April 2005 - 07:52 AM
If it could beep and display "F7", the ERC is not likely to be bad.
So bad touchpad and/or poor connection could be the cause.
Follow Samurai's "my proprietary component isolation technique" if you like!
The Seven
  • 24,677 posts
Posted 21 April 2005 - 09:01 AM
1.  On a wall oven, no.
2.  It's the only thing connecting the touchpanel to the ERC.
3.  Couple of screws on the bottom of the panel.  Piece of pie.  Cut power first.
#8 taylor97
taylor97
  • 5 posts
Posted 21 April 2005 - 10:13 AM
Thank you all so much for all the advice, I will let you know how it goes! :D
#9 Russ Man
Russ Man
  • 5 posts
Posted 21 April 2005 - 10:26 AM
I have changed a lot of ERCs and touch pads on GE ovens....it definitely sounds like a bad touch pad if it continues to beep and then goes to F7.
#10 taylor97
taylor97
  • 5 posts
Posted 21 April 2005 - 05:20 PM
Well, I disconnected the ribbon connector, and no F7!  So, it looks like I will be purchasing a new touchpad.  Thanks so much for all your help appliance guru :banana:
