dave42
replacement universal wine cooler thermostat for Avanti WC400YGB
9 posts in this topic
We have an Avanti WC400YGB wine cooler which completely stopped working. I opened the thermostat housing on the back of the unit and shorted the two leads (it is a 2 lead thermostat). It immediately came on. Of course, Avanti no longer stocks parts for this unit.
Does anyone know where I can buy a universal 2 lead thermostat? The numbers on it are: WPF14P-101-111 and 00.P4761A.Q The unit uses 1.7A at 110V. The thermostat is made by Foshan Tongbao. Thanks.
If you need to get it running on monday get  a temporary cold control Supco p/n SC1002..................that  will keep the vino cold............What is the temperatures you are looking for??  A ranco with the range   37F to 61f.....Do not know your  the location of your "crib" but look up  Armstrong  ( Nor-Mon on the west coast) see what you come up with......
this one may work, if it fits
[user=3641]RegUS_PatOff[/user] wrote:
click on picture
from the Magic Chef  MCWC16M User Manual:
This appliance is intended for storing bottled wine in the temperature range of
5.5C to 19.0C
41.9F to 66.2F
(normal Fridge temperatures are about 38F to 44F)
Mine is attached on the back of the wine cooler(outside the unit). Unfortunately, mine has only 2 contacts. This has 3....unless one is a ground.
Thermostat   # 1411438    NLA
picture ?
WC400YGB Instruction Manual
WC400YGB Parts Manual
I don't have my digital camera with me. I left it at work. Will post picture later this evening, but it does look remarkably like the Magic Chef except it has only 2 contacts.
A cold thermostat with the following temps would be perfect: 41.9F to 66.2F. Does Ranco have a website? I couldn't find one. We are based in NYC.
I found a universal cold control (for an a/c unit) that operates between 52 and 93 deg with 6 deg differential. I would think that should work. We normally keep the wine at about 60-65 deg. The unit is Robertshaw 3030-702. There are several on eBay.
The thermostat unit itself is screwed via a bracket to the outside back of the unit so it will notbe seenunder the counter. Here is a photo of my existing control removed from the wine cooler. The bracket just screws to the outside back wall of the wine cooler. What do you think?
