hoch2
Kitchen Aid Dishwasher Flashing Normal Cycle Light!
13 posts in this topic
Dishwasher will not start.  The light for the normal cycle flashes non-stop and the PC Board has already been replaced.  The dishwasher will not start nor will the dishwasher drain.  We have tried turning off the circuit breaker for half an hour but to no avail.  What do you think it is?
Wayne
Model- kuds011jblo     recheck this number, there will not be a 11 in the model number, the second 1 will be a letter, the tech sheet should tell you how to re-set the control board but need the correct tech sheet. This will also be found in your dishwasher....
Here is the link to a service pointer, however you will need to see what is wrong with your heat circuit also so you do not keep getting this code, if the CLEAN light is blinking 7 times. If the normal light is blinking instead please confirm...
Thanks Pegi.  The model number of the Kitchen Aid dishwasher is kuds1ijblo and actually there are no service instructions on the panel under the dishwasher.  We confirmed this with Whirlpool who said they stopped putting them in there.  So I don't know if it needs a new touchpad or what?
Wayne
This service pointer may also address your problem closer than the clean light blinking 7 times, the stuck key pad..
[align=left]Dishwasher will stop in mid-cycle and will not advance.[/align]
[align=left]One or more of the cycle, option and status indicator lights[/align]
[align=left]will blink.[/align]
[align=left]K8178151[/align]
[align=left]January 2001[/align]
[align=left]The electronic control is reacting to higher than normal[/align]
[align=left]line voltage, (over 125 volts), and higher than normal line[/align]
[align=left]signal distortion that exists in some parts of the country.[/align]
[align=left]A revised electronic control, part #8530909, is available[/align]
[align=left]to better handle high voltage conditions. The current stock[/align]
[align=left]of replacement electronic controls has been reworked, to[/align]
[align=left]supplement production controls being produced. Modified[/align]
[align=left]controls will have a label, “REWORKED HI-LINE” to[/align]
[align=left]identify them as reworked controls and are approved as[/align]
[align=left]service replacements.[/align]
[align=left]NOTE: If the line voltage is normal and a single Cycle,[/align]
[align=left]Option or Rinse Only light is blinking, the cause is usually[/align]
[align=left]a stuck or shorted keypad on the active overlay, not the[/align]
[align=left]control. A resistance check of the active overlay should[/align]
[align=left]always be made, using the keypad matrix in the product[/align]
[align=left]tech sheet, prior to replacing the electronic control.[/align]
So I guess I need a new keypad at this point?
Wayne
Sounds like it at this point if you have already replaced the control board...might see if you can carefully unstick the stuck key??  Have nothing to lose, would not think.  Will be back to post a link to your tech sheet.....
Please recheck the model number, not finding KUDS1IJBL0
Pegi,
That is the serial number from directly from my dishwasher on the manual it says kuds01ij.  Hopefully that will do the trick.  How do I unstick the keys?
Wayne
I have not tried this but have read where others have done this on the touchpads on ranges, perhaps someone in here who has tried this can help him with what to do??  Will re-look for the tech sheet.
You need a new touch panel. Slam dunk.
