clicking noise
6 replies to this topic
#1 jc7765
jc7765
  • 4 posts
Posted 07 September 2005 - 07:46 AM
this washer works fine,but it makes a clicking noise when you use every speed except heavy duty
on the agitate it is kind of annoying.thanks:?
#2 Pegi
Pegi
  • Appliantologist
  • 13,120 posts
Posted 07 September 2005 - 07:57 AM
kenmore 70 series model 110.20702990
Where is this noise coming from, the agitator or underneath by the motor/tranny area...
#3 jc7765
jc7765
  • 4 posts
Posted 07 September 2005 - 11:27 AM
;)   it sounds like the noise is coming from underneath
#4 Pegi
Pegi
  • Appliantologist
  • 13,120 posts
Posted 07 September 2005 - 11:41 AM
Only things down there are the motor, pump, tranny and clutch/break assy.  Cannot imagine what would cause this on all cycles except normal speed unless it is the motor making the noise.
#5 mkroll
mkroll
  • 1 posts
Posted 27 May 2006 - 01:58 PM
I saw this post and wondered if you ever found the cause.
My kenmore washer started making the same noise today.  Everything sounds fine in the heavy duty setting but on the slower settings it makes loud clicking sounds
#6 Mad Mac
Mad Mac
  • Appliantologist
  • 1,444 posts
Posted 27 May 2006 - 02:39 PM
If working correctly on one or more speeds, then it's the run winding of the motor for the affected speed(s) not getting power. Machine tries to start, drops out, repeats until motor overheats and trips out on thermal overload. Check all connections at the motor, that's usually the problem.
Mad Mac....Pray to God he's out there....somewhere.
    Shōgun
  • Master Samurai Tech
  • 30,577 posts
Posted 29 May 2006 - 06:14 AM
And don't forget to check the simple things, like the drive coupler: http://fixitnow.com/...t-drive-washer/
