LG front loading washing machine is flooding, model wm2487hwma.
7 replies to this topic
#1 mstjohn9
mstjohn9
  • 5 posts
Posted 07 May 2010 - 07:32 AM
Hey folks,
I recently reinstalled a 2-year-old LG front loading washer after an extensive home renovation project that included new plumbing and greatly increased water pressure.
Since then the previously problem-free machine has been filling on its own, sometimes slowly and sometimes very quickly, after it's finished its cycle and is presumably off.
The first time it filled I got an error code indicating a water inlet valve problem. But after running the machine I've had intermittent periods of slow or no filling and no further error codes even when it's filled to the middle of the door.
On some occasions, the problem has disappeared temporarily after I drained the drum completely using the hose near the pump filter. Other times, this hasn't had much effect.
I've had a possibly related problem with a stopped up shower head caused by trash in the supply lines. But I haven't been able to get to the inlets to check because of the tight fit in the utility closet. I also haven't been able to check the drain hose for a potential siphoning problem, though I don't suspect this as the cause because the water in the drum has been clear.
What do you think? Test the water pressure first, then remove and inspect the valve for any trash that may be keeping it open? Then replace it if if no trash can be found? Or maybe this beleaguered novice is completely off base.
Mstjohn9
#2 RegUS_PatOff
  • Academy Instructor
  • 33,588 posts
Posted 07 May 2010 - 08:04 AM
[user=66344]mstjohn9[/user] wrote:
... extensive home renovation project that included new plumbing ...
... machine has been filling on its own, ... is presumably off.
... stopped up shower head caused by trash in the supply lines.
... remove and inspect the valve for any trash that may be keeping it open? ... Then replace it if if no trash can be found?
Sounds like sediment inside the Water Valves ...
You could try "flushing" each Water Valve by disconnecting one Hose from the House Faucet end, and placing into a Bucket.
Start by disconnecting the cold Water Hose end.
Run a warm Wash Cycle.
some hot water will back-flow out the cold Water Hose.
Repeat with hot Water hose..
#3 mstjohn9
mstjohn9
  • 5 posts
Posted 07 May 2010 - 08:34 AM
I'll check it out. Thanks a bunch.
    Shōgun
  • Master Samurai Tech
  • 30,015 posts
Posted 08 May 2010 - 04:42 AM
Water inlet valve assembly part link ==> Click
#5 mstjohn9
mstjohn9
  • 5 posts
Posted 10 May 2010 - 05:08 AM
Just some information.
This washer wants to fill on its own after completing a full cycle. But if I drain the drum completely, it seems to stop until I do another load. That seems to indicate a siphoning problem to me, but I still won't know until I can move it past some plumbing obstacles and take a look at the drain hose.
#6 denrayr
denrayr
  • 1,135 posts
Posted 10 May 2010 - 06:20 AM
Hey folks,
Mstjohn9
how high is it? also, did you flush the lines before reconnecting the washer? after doing plumbing work, there will be debris knocked loose in the lines. If this debris isnt flushed out, it will end up in the water valves.
RedRock Appliance Service
435-773-7838
www.redrockrepair.com
Serving St George and Southern Utah
#7 mstjohn9
mstjohn9
  • 5 posts
Posted 10 May 2010 - 08:01 AM
Hi Denrayr,
We've had problems with lines that were not flushed before ithe installation of such things as the showerhead -- and it's possible we've got trash in the washer lines, too.
A previous post suggested a way to flush out both lines, and that's the first thing on my to-do list once I get past the obstructions left by a plumber. But I'm also worried that the drain hose was installed in a way that has created a siphoning problem. If I drain the machine manually after a cycle finishes, the flooding usually stops until I run another load.
#8 mstjohn9
mstjohn9
  • 5 posts
Posted 17 May 2010 - 06:23 AM
Finally got some access to the back of this stacked washer-dryer unit.
Reached past all the plumbing obstructions left by a careless boiler guy and discovered that the equally careless installer had pushed about 3 feet or more of the drain hose down into the new drain pipe. The last foot or so was covered with slime from being in standing gray water from the machine.
I'm thinking this oversight created a siphoning condition and caused the drum to flood after the wash cycle was over.
Pushed the hose back in about 8-10 inches and ran 3 consecutive loads without the previous flooding symptoms.
Looks like we've got a simple fix for now -- and I'll be shortening the hose and installing the missing retainer, which I found in a box -- as soon as I'm able to get the machine out a little farther.
