lanie
Bosch 5315UC/06 Model
10 posts in this topic
When going through the wash cycle my dishwasher is getting stuck on 1.  The water does not drain out and keeps sloshing around in the machine.  It's not going through the normal dry cycle either and in order to get the water out I have to clear the wash cycle by pressing the two required buttons. The rinse and hold cycle fills and drains fine. Thanks for any insight.
It sounds like the DW is not heating. If you can see a heater in the bottom, check it for holes or splits. Is there an error code on the screen when it stops?
Thanks for your response.
The Bosch has no heater...it has an aqua sensor that heats the water.   If the aqua sensor was bad why would that make the counter on the dishwasher stay on 1?  Thanks for any additional info on this.
A sensor that doubles as a heater!? Even if that were true (which it ain't) the "sensor" would draw 11 amps and you could measure this with your clampon ampmeter. Do that and tell us what you get.
The aqua sensor is a water clarity sensor, the dirtier the water, the longer the wash and more rinses.  If you cant see an element in the bottom, then the heater will be in line with the wash motor.  It will be a 6 inch long metal cylinder, check this for resistance.  It could also be the circuit board or a temperature sensor, but it would be best to check the heater first.  I'm not sure how your DW comes apart, as I dont recognize the model no,  Sorry :)
After doing some parts checking there is a heater assembly that goes together with the aqua sensor.  It's not where you can see it so we will have to pull the machine out to get to it from the back.
Thanks for all your replies.
Problem solved!!  We thought we would try replacing the control modular.  This apparently tells the machine when to let the water out and when to begin the dry cycle.
It's now working 100%correctly.
the problem was actually in the heating circuit as the others had suggested to you,this is a common failure for these as the relay on the control that closes to send power to the heater overheats the solder spots on the board and ceases to connect- the "1" which appears on your display is actually a failure code for the heating circuit. this is apt to happen again,so my advise is to hang on to your old control board,inspect and repair the poor solder joints on it and keep it around to change out the next time it fails.  most of the guys i work with carry a used/repaired board with them for this purpose.
Thanks kdog for the suggestion.  This is actually the second time we had to install a control modular in this dishwasher so we'll check the wiring on the one we took out and keep it around just in case.
I kind of thought by the responses to my problem that they were suggesting a water heater problem for my machine.  No one ever mentioned the control modular.
remember that the heating circuit involves everything from the control mounted relay to the wiring,heater,thermostat,water pressure switch etc. the chip in the control only sees that there is no current applied to the circuit,so the failure is anywhere that the cicuit may be broken.
