The days of Monkey Boy Service Calls are over...
Click here to check out our fun short course and learn how to get the most out of Appliantology.
wdwerker
GE refrigerator
4 posts in this topic
GE refrigerator problem, water collects in the bottom under the fruit & veg drawer. Sometimes it runs out and makes a puddle on the floor. I had to replace a dying ice maker recently and I thought that it might have been that, but it is still doing it and I replaced the entire icemaker and lines and valve with a factory /dealer install kit. Could it be the automatic defrost causing this?
You need to clean out your defrost drain system, it is clogged either in the freezer or where it goes into the food compartment and down to the drain pan under the frig.
sounds like a great idea, I bet that is exactly it. So how do I clean out that drain, where does it run from and to on a 1989  top freezer  GE fridge. Or is there somplace I can look it up with the model number?
