The days of Monkey Boy Service Calls are over...
Click here to check out our fun short course and learn how to get the most out of Appliantology.
poconored
MAH3000AWW Maytag Washer
5 posts in this topic
even if restarted shuts off in every rinse cycle after 30-40 seconds; shuts off in spin cycle, again after 30-40 seconds - no spin at all now (see below).
This is in either regular or quick cycle - same problem.  just 3 quick clicks x 3 each time, then shuts off.
BTW, still had a slow-spin issue that was never resolved (no spin at all now)...
Appears now something more fried!
Any help, ideas (other than burial ceremony) would be welcome !!!:D
More than likely the motor control board in the bottom of the machine is fried.  Maytag had such a problem with these motor control boards that you have to replace the motor and the motor control board as a kit.  Unplug the machine, take the front off of the machine, reach in and take a look at the motor control board for either a blown fuse or burnt components.
http://servicematters.com/maytag_library/docs/16010061.pdf
Part link for motor and control board kit ==> Click
Great - THANKS !!!
Would this also resolve the 'previous' slow-spin issue?
(or might that be something on upper control board?)
wanted to get a grip on total cost/worst case repair - to judge vs. just buying new washer...)
thanks Again !
Insufficient data. However, in accordance with the 8th Law of the Prophecy, we much fix the obvious problems first.
